system ha interconnect statistics show-scatter-gather-list
Display the high-availability interconnect scatter-gather list entry statistics
The system ha interconnect statistics show-scatter-gather-list command displays the high-availability interconnect device scatter-gather list entry statistics. Out of all possible 32 entries in a scatter-gather list, the command displays only the entries that have valid data.
[-fields <fieldname>,…]-
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ](privilege: advanced) } -
Use this parameter to display all the fields from all nodes in cluster.
[-node {<nodename>|local}]- Node (privilege: advanced)-
Use this parameter to display all the fields from the specified node in the cluster.
[-sge <integer>,…]- Scatter-Gather Entry (privilege: advanced)-
Selects the nodes that match this scatter-gather element index value.
[-total-count <integer>,…]- Total Count (privilege: advanced)-
Selects the nodes that match this parameter value. The value is the total number of times a particular scatter-gather list element is used.
[-total-size <integer>,…]- Total Size (privilege: advanced)-
Selects the nodes that match this parameter value. The value is the total number of bytes written by the high-availability interconnect device using a particular scatter-gather list element.
cluster1::*> system ha interconnect statistics show-scatter-gather-list
Node: ic-f8040-01
Entry Count Size
1 410925 77344493
2 988 1246987
3 72 747325
4 93264 1527155579
8 9 294912
9 9 294912
Node: ic-f8040-02
Entry Count Size
1 1544405 310004390
2 6217 16779908
3 1222 12003411
4 338606 5543436659
6 2 41980
7 2 46136
8 18 589824
9 18 589824
2 entries were displayed.
