ONTAP commands
system ha interconnect statistics show-scatter-gather-list
Display the high-availability interconnect scatter-gather list entry statistics
The system ha interconnect statistics show-scatter-gather-list command displays the high-availability interconnect device scatter-gather list entry statistics. Out of all possible 32 entries in a scatter-gather list, the command displays only the entries that have valid data.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
Use this parameter to display all the fields from all nodes in cluster.
[-node {<nodename>|local}] - Node (privilege: advanced)
Use this parameter to display all the fields from the specified node in the cluster.
[-sge <integer>,…​] - Scatter-Gather Entry (privilege: advanced)
Selects the nodes that match this scatter-gather element index value.
[-total-count <integer>,…​] - Total Count (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of times a particular scatter-gather list element is used.
[-total-size <integer>,…​] - Total Size (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of bytes written by the high-availability interconnect device using a particular scatter-gather list element.
cluster1::*> system ha interconnect statistics show-scatter-gather-list
Node: ic-f8040-01
Entry              Count              Size
    1             410925          77344493
    2                988           1246987
    3                 72            747325
    4              93264        1527155579
    8                  9            294912
    9                  9            294912
Node: ic-f8040-02
Entry              Count              Size
    1            1544405         310004390
    2               6217          16779908
    3               1222          12003411
    4             338606        5543436659
    6                  2             41980
    7                  2             46136
    8                 18            589824
    9                 18            589824
2 entries were displayed.
