system ha interconnect statistics show-scatter-gather-list
PDF of this doc site
Creating your file...
Display the high-availability interconnect scatter-gather list entry statistics
The system ha interconnect statistics show-scatter-gather-list
command displays the high-availability interconnect device scatter-gather list entry statistics. Out of all possible 32 entries in a scatter-gather list, the command displays only the entries that have valid data.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays only the fields that you specify. - |
[-instance ]
Use this parameter to display all the fields from all nodes in cluster.
[-node {<nodename>|local}]
- Node (privilege: advanced)-
Use this parameter to display all the fields from the specified node in the cluster.
[-sge <integer>,…]
- Scatter-Gather Entry (privilege: advanced)-
Selects the nodes that match this scatter-gather element index value.
[-total-count <integer>,…]
- Total Count (privilege: advanced)-
Selects the nodes that match this parameter value. The value is the total number of times a particular scatter-gather list element is used.
[-total-size <integer>,…]
- Total Size (privilege: advanced)-
Selects the nodes that match this parameter value. The value is the total number of bytes written by the high-availability interconnect device using a particular scatter-gather list element.
cluster1::*> system ha interconnect statistics show-scatter-gather-list Node: ic-f8040-01 Entry Count Size ----- ----------------- ---------------- 1 410925 77344493 2 988 1246987 3 72 747325 4 93264 1527155579 8 9 294912 9 9 294912 Node: ic-f8040-02 Entry Count Size ----- ----------------- ---------------- 1 1544405 310004390 2 6217 16779908 3 1222 12003411 4 338606 5543436659 6 2 41980 7 2 46136 8 18 589824 9 18 589824 2 entries were displayed.
