Command reference
vserver vscan on-access-policy file-ext-to-include add
Add to the list of file extensions to include
The vserver vscan on-access-policy file-ext-to-include add command adds a file extension or list of file extensions to include for virus scanning to the specified policy.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver containing the specified on-access policy to which you want to add a file extension or a list of file extensions to include for virus scanning.
-policy-name <Policy name> - Policy
This parameter specifies the name of the on-access policy to which you want to add a file extension or a list of file extensions to include for virus scanning.
-file-ext-to-include <File extension>,…​ - File Extensions to Scan
This parameter specifies the file extension or a list of file extensions to include for virus scanning.
The following example adds a list of file extensions to include for virus scanning to the specified on-access policy.
cluster1::> vserver vscan on-access-policy file-ext-to-include add -vserver vs1
            -policy-name policy1 -file-ext-to-include "mp*","tx*"
cluster1::> vserver vscan on-access-policy file-ext-to-include show -vserver vs1
Vserver: vs1
                     Policy: policy1
    File Extensions to Scan: mp*, tx*, wav
