volume quota resize
Resize quotas for volumes
This command resizes the quota limits for the quotas currently in effect for the specified volume. It creates a job to resize quotas. You can monitor the progress of the job by using the job show and job watch-progress commands.
NOTE:
Quotas must be activated before quota limits can be resized.
-vserver <vserver name>- Vserver Name-
This specifies the name of the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This specifies the name of the volume on which you are resizing the quota limits and threshold.
[-foreground <true>]- Foreground Process-
This optionally specifies whether the job created for resizing quotas runs as a foreground process. The default setting is
false(that is, the operation runs in the background). When set totrue, the command will not return until the job completes.
The following example resizes quotas on the volume named vol1 , which exists on Vserver vs0 .
cluster1::> volume quota resize -vserver vs0 -volume vol1 [Job 34] Job is queued: Quota RESIZE Operation on vserver vs0 volume vol1.
The following example uses a 7G-compatible command to resize quotas on the volume named vol1 which exists on Vserver vs0 .
cluster1::> vserver context vs0 vs0::> quota resize vol1 [Job 35] Job is queued: Quota RESIZE Operation on vserver vs0 volume vol1.
