volume quota resize
Resize quotas for volumes
This command resizes the quota limits for the quotas currently in effect for the specified volume. It creates a job to resize quotas. You can monitor the progress of the job by using the job show and job watch-progress commands.
Note Quotas must be activated before quota limits can be resized.
-vserver <vserver name> - Vserver Name
This specifies the name of the Vserver on which the volume is located.
-volume <volume name> - Volume Name
This specifies the name of the volume on which you are resizing the quota limits and threshold.
[-foreground <true>] - Foreground Process
This optionally specifies whether the job created for resizing quotas runs as a foreground process. The default setting is false (that is, the operation runs in the background). When set to true , the command will not return until the job completes.
The following example resizes quotas on the volume named vol1 , which exists on Vserver vs0 .
cluster1::> volume quota resize -vserver vs0 -volume vol1
[Job 34] Job is queued: Quota RESIZE Operation on vserver vs0 volume vol1.
The following example uses a 7G-compatible command to resize quotas on the volume named vol1 which exists on Vserver vs0 .
cluster1::> vserver context vs0
vs0::> quota resize vol1
[Job 35] Job is queued: Quota RESIZE Operation on vserver vs0 volume vol1.
