volume quota resize
Resize quotas for volumes
This command resizes the quota limits for the quotas currently in effect for the specified volume. It creates a job to resize quotas. You can monitor the progress of the job by using the job show and job watch-progress commands.
Quotas must be activated before quota limits can be resized. |
-vserver <vserver name>
- Vserver Name-
This specifies the name of the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume on which you are resizing the quota limits and threshold.
[-foreground <true>]
- Foreground Process-
This optionally specifies whether the job created for resizing quotas runs as a foreground process. The default setting is
false
(that is, the operation runs in the background). When set totrue
, the command will not return until the job completes.
The following example resizes quotas on the volume named vol1
, which exists on Vserver vs0
cluster1::> volume quota resize -vserver vs0 -volume vol1 [Job 34] Job is queued: Quota RESIZE Operation on vserver vs0 volume vol1.
The following example uses a 7G-compatible command to resize quotas on the volume named vol1
cluster1::> vserver context vs0 vs0::> quota resize vol1 [Job 35] Job is queued: Quota RESIZE Operation on vserver vs0 volume vol1.
