storage raidlm policy show
Display the policies
The storage raidlm policy show command displays information about Raid Layout Manager policies and its value. Raid Layout Manager is a user space process which polls system configuration, detect conflict if it deviates from NetApp recommended best practices, and resolve conflict.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node names (privilege: advanced)-
This parameter specifies the node on which this Raid Layout Manager policy is enabled.
[-policy-name <text>]- Policy name for Raid-lm (privilege: advanced)-
All the Raid Layout Manager policy.
[-policy-type <text>]- Policy type for Raid-lm (privilege: advanced)-
Policy type of the Raid Layout Manager policy.
[-is-enabled {true|false}]- Is Policy Enabled? (privilege: advanced)-
Value of the Raid Layout Manager policy that have the specified name.
The following example shows the RAID-LM policy settings for node1 and node2:
cluster1::> storage raidlm policy show -node node* -policy-name auto_unpartition_on_spares_low
Node Policy Type Policy Name Is Enabled
node1
Shared-Disk auto_unpartition_on_spares_low true
node2
2 entries were displayed.
