ONTAP commands
storage raidlm policy show
Display the policies
The storage raidlm policy show command displays information about Raid Layout Manager policies and its value. Raid Layout Manager is a user space process which polls system configuration, detect conflict if it deviates from NetApp recommended best practices, and resolve conflict.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node <nodename>] - Node names (privilege: advanced)
This parameter specifies the node on which this Raid Layout Manager policy is enabled.
[-policy-name <text>] - Policy name for Raid-lm (privilege: advanced)
All the Raid Layout Manager policy.
[-policy-type <text>] - Policy type for Raid-lm (privilege: advanced)
Policy type of the Raid Layout Manager policy.
[-is-enabled {true|false}] - Is Policy Enabled? (privilege: advanced)
Value of the Raid Layout Manager policy that have the specified name.
The following example shows the RAID-LM policy settings for node1 and node2:
cluster1::> storage raidlm policy show -node node* -policy-name auto_unpartition_on_spares_low
Node                Policy Type  Policy Name                    Is Enabled
node1
        Shared-Disk  auto_unpartition_on_spares_low true
node2
2 entries were displayed.
