storage failover hwassist stats show
Display hwassist statistics
The` storage failover hwassist stats show ` command displays statistics about the hardware assist alerts processed by a node. The command displays the following information for each alert:
Locally enabled.
Partner Inactive Reason.
Alert type.
Event that triggered the alert.
The number of times the alert has been received.
Whether takeover was possible on receiving the alert.
The last time at which the alert was received.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the hwassist statistics for the specified node.
The following example displays the hwassist statistics for the node ha1:
cluster1::> storage failover hwassist stats show -node ha1 Node: ha1 Local Enabled: true Partner Inactive Reason: - Alert Type Alert Event Count Takeover Last Received ------------ -------------------- ------ --------- -------------------- system_down power_loss 0 Yes --- system_down l2_watchdog_reset 0 Yes --- system_down power_off_via_rlm 0 Yes --- system_down power_cycle_via_rlm 0 Yes --- system_down reset_via_rlm 0 Yes --- system_down power_off_via_sp 0 Yes --- system_down power_cycle_via_sp 0 Yes --- system_down reset_via_sp 0 Yes --- system_down dimm_uecc_error 0 Yes --- system_down post_error 0 No --- system_down abnormal_reboot 0 No --- system_down loss_of_heartbeat 0 No --- keep_alive periodic_message 10 No Wed Mar 9 13:41:28 EST 2016 test test 0 No --- ID_mismatch --- 0 --- --- Key_mismatch --- 0 --- --- Unknown --- 0 --- --- alerts_throttled 0 --- ---
The following example displays the hwassist statistics for the node ha1 where hardware assist hardware is not supported.
cluster1::> storage failover hwassist stats show -node ha1 Node: ha1 Local Enabled: false Partner Inactive Reason: HW assist is not supported on partner. Alert Type Alert Event Count Takeover Last Received ------------ -------------------- ------ --------- -------------------- -
