storage failover hwassist stats show
Display hwassist statistics
The` storage failover hwassist stats show ` command displays statistics about the hardware assist alerts processed by a node. The command displays the following information for each alert:
  • Locally enabled.
  • Partner Inactive Reason.
  • Alert type.
  • Event that triggered the alert.
  • The number of times the alert has been received.
  • Whether takeover was possible on receiving the alert.
  • The last time at which the alert was received.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the hwassist statistics for the specified node.
The following example displays the hwassist statistics for the node ha1:
cluster1::> storage failover hwassist stats show -node ha1
Node: ha1
              Local Enabled: true
    Partner Inactive Reason: -
Alert Type   Alert Event           Count Takeover  Last Received
    system_down  power_loss                0 Yes       ---
    system_down  l2_watchdog_reset         0 Yes       ---
    system_down  power_off_via_rlm         0 Yes       ---
    system_down  power_cycle_via_rlm       0 Yes       ---
    system_down  reset_via_rlm             0 Yes       ---
    system_down  power_off_via_sp          0 Yes       ---
    system_down  power_cycle_via_sp        0 Yes       ---
    system_down  reset_via_sp              0 Yes       ---
    system_down  dimm_uecc_error           0 Yes       ---
    system_down  post_error                0 No        ---
    system_down  abnormal_reboot           0 No        ---
    system_down  loss_of_heartbeat         0 No        ---
    keep_alive   periodic_message         10 No        Wed Mar  9 13:41:28 EST 2016
    test         test                      0 No        ---
    ID_mismatch  ---                       0 ---       ---
    Key_mismatch ---                       0 ---       ---
    Unknown      ---                       0 ---       ---
                 alerts_throttled          0 ---       ---
The following example displays the hwassist statistics for the node ha1 where hardware assist hardware is not supported.
Node: ha1
              Local Enabled: false
    Partner Inactive Reason: HW assist is not supported on partner.
