ONTAP commands
storage failover hwassist stats show
Display hwassist statistics
The` storage failover hwassist stats show ` command displays statistics about the hardware assist alerts processed by a node. The command displays the following information for each alert:
  • Locally enabled.
  • Partner Inactive Reason.
  • Alert type.
  • Event that triggered the alert.
  • The number of times the alert has been received.
  • Whether takeover was possible on receiving the alert.
  • The last time at which the alert was received.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the hwassist statistics for the specified node.
[-enabled {true|false}] - Local Hardware Assist Enabled
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified enabled state.
[-local-inactive <text>] - Local Node's Hwassist Inactive Status Reason
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified inactive reason.
[-power-loss <text>] - Power Loss Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power-loss event.
[-watchdog-reset <text>] - Watchdog Reset Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified watchdog-reset event.
[-power-off-via-rlm <text>] - Power Off by Using RLM
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power off event via Remote LAN Manager.
[-power-cycle-via-rlm <text>] - Power Cycle by Using RLM
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power cycle event via Remote LAN Manager.
[-reset-via-rlm <text>] - System Reset by Using RLM
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified reset event via Remote LAN Manager.
[-power-off-via-sp <text>] - Power Off by Using SP
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power off event via Service Processor.
[-power-cycle-via-sp <text>] - Power Cycle by Using SP
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified power cycle event via Service Processor.
[-reset-via-sp <text>] - System Reset by Using SP
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified reset event via Service Processor.
[-dimm-uecc-error <text>] - DIMM UECC Fatal Error Detected by Storage OS
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified DIMM error event.
[-post-error <text>] - POST Error Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified post error event.
[-abnormal-reboot <text>] - Abnormal Reboot Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified abnormal reboot event.
[-loss-of-heartbeat <text>] - Loss of Heartbeat Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified loss of heartbeat event.
[-keep-alive <text>] - Periodic Message Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified keep alive event.
[-test <text>] - Test Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified test event.
[-bad-nvram-id <text>] - Bad NVRAM ID Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified bad NVRAM ID event.
[-ss-mismatch <text>] - Shared Secret Key Mismatch Alert
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified shared secret mismatch event.
[-unknown-alerts <text>] - Unknown Alerts
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified unknown alerts event.
[-times-throttled <text>] - Number of Throttled Alerts
If you specify this parameter, the command displays information only about hwassist statistics on nodes with the specified times throttled event.
The following example displays the hwassist statistics for the node ha1:
cluster1::> storage failover hwassist stats show -node ha1
Node: ha1
              Local Enabled: true
    Partner Inactive Reason: -
Alert Type   Alert Event           Count Takeover  Last Received
    system_down  power_loss                0 Yes       ---
    system_down  l2_watchdog_reset         0 Yes       ---
    system_down  power_off_via_rlm         0 Yes       ---
    system_down  power_cycle_via_rlm       0 Yes       ---
    system_down  reset_via_rlm             0 Yes       ---
    system_down  power_off_via_sp          0 Yes       ---
    system_down  power_cycle_via_sp        0 Yes       ---
    system_down  reset_via_sp              0 Yes       ---
    system_down  dimm_uecc_error           0 Yes       ---
    system_down  post_error                0 No        ---
    system_down  abnormal_reboot           0 No        ---
    system_down  loss_of_heartbeat         0 No        ---
    keep_alive   periodic_message         10 No        Wed Mar  9 13:41:28 EST 2016
    test         test                      0 No        ---
    ID_mismatch  ---                       0 ---       ---
    Key_mismatch ---                       0 ---       ---
    Unknown      ---                       0 ---       ---
                 alerts_throttled          0 ---       ---
The following example displays the hwassist statistics for the node ha1 where hardware assist hardware is not supported.
Node: ha1
              Local Enabled: false
    Partner Inactive Reason: HW assist is not supported on partner.
