storage stackmon topology show
Display stackmon topology
The storage stackmon topology show
command displays the shelf topology reported by stackmon, SES, and the disk driver on all nodes. Note: all node/shelf pairs are shown, even if the node is not connected to the shelf. The chain-handle, ses-channels, and disk-channels fields will be empty ("-") when the node is not connected to the shelf.
[-fields <fieldname>,…]
Displays output in column style about the specified fields.
[-instance ]
Displays expanded information for stackmon topology on all nodes. If a node and shelf-uid are specified, then this parameter displays the same detailed information for the specified port as does the -node and -shelf-uid parameters.
[-node {<nodename>|local}]
- Node (privilege: advanced)-
Displays the topology information for the specified node.
[-shelf-uid <integer>]
- Shelf UID (privilege: advanced)-
Displays the topology information for the specified shelf. Use storage shelf show
-fields
shelf-uuid
to find the shelf-uid. [-stack-id <integer>]
- Stack ID (privilege: advanced)-
Displays the topology information for shelves with the specified stack-id.
[-chain-handle <integer>]
- Stackmon Chain Handle (privilege: advanced)-
Displays the topology information for shelves with the specified chain-handle.
[-reconcile-state {processing|succeeded|failed}]
- Reconcile State (privilege: advanced)-
Displays the topology information for shelves with the specified reconcile-state.
[-ses-channels <text>,…]
- SES Channels (privilege: advanced)-
Displays the topology information for shelves with the specified SES channels.
[-disk-channels <text>,…]
- Disk Channels (privilege: advanced)-
Displays the topology information for shelves with the specified disk channels.
[-ses-disk-match {true|false}]
- SES Matches Disk Topology (privilege: advanced)-
Displays the topology information for shelves that are seen on the same channels by SES and the disk driver.
The following example displays topology information for all shelves:
cluster1::*> storage stackmon topology show Failed Node Shelf Chain Handle Stack Reconcile ---- -------------------- -------------------- ----- --------- node1 123370712932616784 1152922178327261751 1 false 292812051842665040 1152922178327261751 1 false 4342319975102154064 1152922178327258740 2 false 4558492757215937872 1152922178327258740 2 false 5350844816656434512 1152922178327261751 1 false 9274403680772754000 1152922178327261751 1 false 9346461274810681936 1152922178327258740 2 false 10786768730639108688 1152922178327258740 2 false node2 123370712932616784 1152922178315916511 1 false 292812051842665040 1152922178315916511 1 false 4342319975102154064 1152922178315913225 2 false 4558492757215937872 1152922178315913225 2 false 5350844816656434512 1152922178315916511 1 false 9274403680772754000 1152922178315916511 1 false 9346461274810681936 1152922178315913225 2 false 10786768730639108688 1152922178315913225 2 false node3 123370712932616784 1152922178329970138 1 false 292812051842665040 1152922178329970138 1 false 4342319975102154064 1152922178329977389 2 false 4558492757215937872 1152922178329977389 2 false 5350844816656434512 1152922178329970138 1 false 9274403680772754000 1152922178329970138 1 false 9346461274810681936 1152922178329977389 2 false 10786768730639108688 1152922178329977389 2 false node4 123370712932616784 1152922178327647260 1 false 292812051842665040 1152922178327647260 1 false 4342319975102154064 1152922178327645097 2 false 4558492757215937872 1152922178327645097 2 false 5350844816656434512 1152922178327647260 1 false 9274403680772754000 1152922178327647260 1 false 9346461274810681936 1152922178327645097 2 false 10786768730639108688 1152922178327645097 2 false 32 entries were displayed.
