storage stackmon topology show
Display stackmon topology
The storage stackmon topology show command displays the shelf topology reported by stackmon, SES, and the disk driver on all nodes. Note: all node/shelf pairs are shown, even if the node is not connected to the shelf. The chain-handle, ses-channels, and disk-channels fields will be empty ("-") when the node is not connected to the shelf.
[-fields <fieldname>,…] -
Displays output in column style about the specified fields.
[-instance ]} -
Displays expanded information for stackmon topology on all nodes. If a node and shelf-uid are specified, then this parameter displays the same detailed information for the specified port as does the -node and -shelf-uid parameters.
[-node {<nodename>|local}]- Node (privilege: advanced)-
Displays the topology information for the specified node.
[-shelf-uid <integer>]- Shelf UID (privilege: advanced)-
Displays the topology information for the specified shelf. Use storage shelf show
-fieldsshelf-uuidto find the shelf-uid. [-stack-id <integer>]- Stack ID (privilege: advanced)-
Displays the topology information for shelves with the specified stack-id.
[-chain-handle <integer>]- Stackmon Chain Handle (privilege: advanced)-
Displays the topology information for shelves with the specified chain-handle.
[-reconcile-state {processing|succeeded|failed}]- Reconcile State (privilege: advanced)-
Displays the topology information for shelves with the specified reconcile-state.
[-ses-channels <text>,…]- SES Channels (privilege: advanced)-
Displays the topology information for shelves with the specified SES channels.
[-disk-channels <text>,…]- Disk Channels (privilege: advanced)-
Displays the topology information for shelves with the specified disk channels.
[-ses-disk-match {true|false}]- SES Matches Disk Topology (privilege: advanced)-
Displays the topology information for shelves that are seen on the same channels by SES and the disk driver.
The following example displays topology information for all shelves:
cluster1::*> storage stackmon topology show
Failed
Node Shelf Chain Handle Stack Reconcile
node1
123370712932616784 1152922178327261751 1 false
292812051842665040 1152922178327261751 1 false
4342319975102154064 1152922178327258740 2 false
4558492757215937872 1152922178327258740 2 false
5350844816656434512 1152922178327261751 1 false
9274403680772754000 1152922178327261751 1 false
9346461274810681936 1152922178327258740 2 false
10786768730639108688 1152922178327258740 2 false
node2
123370712932616784 1152922178315916511 1 false
292812051842665040 1152922178315916511 1 false
4342319975102154064 1152922178315913225 2 false
4558492757215937872 1152922178315913225 2 false
5350844816656434512 1152922178315916511 1 false
9274403680772754000 1152922178315916511 1 false
9346461274810681936 1152922178315913225 2 false
10786768730639108688 1152922178315913225 2 false
node3
123370712932616784 1152922178329970138 1 false
292812051842665040 1152922178329970138 1 false
4342319975102154064 1152922178329977389 2 false
4558492757215937872 1152922178329977389 2 false
5350844816656434512 1152922178329970138 1 false
9274403680772754000 1152922178329970138 1 false
9346461274810681936 1152922178329977389 2 false
10786768730639108688 1152922178329977389 2 false
node4
123370712932616784 1152922178327647260 1 false
292812051842665040 1152922178327647260 1 false
4342319975102154064 1152922178327645097 2 false
4558492757215937872 1152922178327645097 2 false
5350844816656434512 1152922178327647260 1 false
9274403680772754000 1152922178327647260 1 false
9346461274810681936 1152922178327645097 2 false
10786768730639108688 1152922178327645097 2 false
32 entries were displayed.
