ONTAP commands
storage stackmon topology show
Display stackmon topology
The storage stackmon topology show command displays the shelf topology reported by stackmon, SES, and the disk driver on all nodes. Note: all node/shelf pairs are shown, even if the node is not connected to the shelf. The chain-handle, ses-channels, and disk-channels fields will be empty ("-") when the node is not connected to the shelf.
[-fields <fieldname>,…​]
Displays output in column style about the specified fields.
| [-instance ] (privilege: advanced) }
Displays expanded information for stackmon topology on all nodes. If a node and shelf-uid are specified, then this parameter displays the same detailed information for the specified port as does the -node and -shelf-uid parameters.
[-node {<nodename>|local}] - Node (privilege: advanced)
Displays the topology information for the specified node.
[-shelf-uid <integer>] - Shelf UID (privilege: advanced)
Displays the topology information for the specified shelf. Use storage shelf show-fields shelf-uuid to find the shelf-uid.
[-stack-id <integer>] - Stack ID (privilege: advanced)
Displays the topology information for shelves with the specified stack-id.
[-chain-handle <integer>] - Stackmon Chain Handle (privilege: advanced)
Displays the topology information for shelves with the specified chain-handle.
[-reconcile-state {processing|succeeded|failed}] - Reconcile State (privilege: advanced)
Displays the topology information for shelves with the specified reconcile-state.
[-ses-channels <text>,…​] - SES Channels (privilege: advanced)
Displays the topology information for shelves with the specified SES channels.
[-disk-channels <text>,…​] - Disk Channels (privilege: advanced)
Displays the topology information for shelves with the specified disk channels.
[-ses-disk-match {true|false}] - SES Matches Disk Topology (privilege: advanced)
Displays the topology information for shelves that are seen on the same channels by SES and the disk driver.
The following example displays topology information for all shelves:
cluster1::*> storage stackmon topology show
Failed
Node Shelf                Chain Handle         Stack Reconcile
node1
       123370712932616784  1152922178327261751     1 false
       292812051842665040  1152922178327261751     1 false
      4342319975102154064  1152922178327258740     2 false
      4558492757215937872  1152922178327258740     2 false
      5350844816656434512  1152922178327261751     1 false
      9274403680772754000  1152922178327261751     1 false
      9346461274810681936  1152922178327258740     2 false
     10786768730639108688  1152922178327258740     2 false
node2
       123370712932616784  1152922178315916511     1 false
       292812051842665040  1152922178315916511     1 false
      4342319975102154064  1152922178315913225     2 false
      4558492757215937872  1152922178315913225     2 false
      5350844816656434512  1152922178315916511     1 false
      9274403680772754000  1152922178315916511     1 false
      9346461274810681936  1152922178315913225     2 false
     10786768730639108688  1152922178315913225     2 false
node3
       123370712932616784  1152922178329970138     1 false
       292812051842665040  1152922178329970138     1 false
      4342319975102154064  1152922178329977389     2 false
      4558492757215937872  1152922178329977389     2 false
      5350844816656434512  1152922178329970138     1 false
      9274403680772754000  1152922178329970138     1 false
      9346461274810681936  1152922178329977389     2 false
     10786768730639108688  1152922178329977389     2 false
node4
       123370712932616784  1152922178327647260     1 false
       292812051842665040  1152922178327647260     1 false
      4342319975102154064  1152922178327645097     2 false
      4558492757215937872  1152922178327645097     2 false
      5350844816656434512  1152922178327647260     1 false
      9274403680772754000  1152922178327647260     1 false
      9346461274810681936  1152922178327645097     2 false
     10786768730639108688  1152922178327645097     2 false
32 entries were displayed.
