storage stackmon topology show
Display stackmon topology
The storage stackmon topology show command displays the shelf topology reported by stackmon, SES, and the disk driver on all nodes. Note: all node/shelf pairs are shown, even if the node is not connected to the shelf. The chain-handle, ses-channels, and disk-channels fields will be empty ("-") when the node is not connected to the shelf.
- { [-fields <fieldname>,…]
Displays output in column style about the specified fields.
- | [-instance ]}
Displays expanded information for stackmon topology on all nodes. If a node and shelf-uid are specified, then this parameter displays the same detailed information for the specified port as does the -node and -shelf-uid parameters.
- [-node {<nodename>|local}]- Node (privilege: advanced)
Displays the topology information for the specified node.
- [-shelf-uid <integer>]- Shelf UID (privilege: advanced)
Displays the topology information for the specified shelf. Use storage shelf show -fieldsshelf-uuidto find the shelf-uid.
- [-stack-id <integer>]- Stack ID (privilege: advanced)
Displays the topology information for shelves with the specified stack-id.
- [-chain-handle <integer>]- Stackmon Chain Handle (privilege: advanced)
Displays the topology information for shelves with the specified chain-handle.
- [-reconcile-state {processing|succeeded|failed}]- Reconcile State (privilege: advanced)
Displays the topology information for shelves with the specified reconcile-state.
- [-ses-channels <text>,…]- SES Channels (privilege: advanced)
Displays the topology information for shelves with the specified SES channels.
- [-disk-channels <text>,…]- Disk Channels (privilege: advanced)
Displays the topology information for shelves with the specified disk channels.
- [-ses-disk-match {true|false}]- SES Matches Disk Topology (privilege: advanced)
Displays the topology information for shelves that are seen on the same channels by SES and the disk driver.
The following example displays topology information for all shelves:
cluster1::*> storage stackmon topology show
Failed
Node Shelf                Chain Handle         Stack Reconcile
node1
       123370712932616784  1152922178327261751     1 false
       292812051842665040  1152922178327261751     1 false
      4342319975102154064  1152922178327258740     2 false
      4558492757215937872  1152922178327258740     2 false
      5350844816656434512  1152922178327261751     1 false
      9274403680772754000  1152922178327261751     1 false
      9346461274810681936  1152922178327258740     2 false
     10786768730639108688  1152922178327258740     2 false
node2
       123370712932616784  1152922178315916511     1 false
       292812051842665040  1152922178315916511     1 false
      4342319975102154064  1152922178315913225     2 false
      4558492757215937872  1152922178315913225     2 false
      5350844816656434512  1152922178315916511     1 false
      9274403680772754000  1152922178315916511     1 false
      9346461274810681936  1152922178315913225     2 false
     10786768730639108688  1152922178315913225     2 false
node3
       123370712932616784  1152922178329970138     1 false
       292812051842665040  1152922178329970138     1 false
      4342319975102154064  1152922178329977389     2 false
      4558492757215937872  1152922178329977389     2 false
      5350844816656434512  1152922178329970138     1 false
      9274403680772754000  1152922178329970138     1 false
      9346461274810681936  1152922178329977389     2 false
     10786768730639108688  1152922178329977389     2 false
node4
       123370712932616784  1152922178327647260     1 false
       292812051842665040  1152922178327647260     1 false
      4342319975102154064  1152922178327645097     2 false
      4558492757215937872  1152922178327645097     2 false
      5350844816656434512  1152922178327647260     1 false
      9274403680772754000  1152922178327647260     1 false
      9346461274810681936  1152922178327645097     2 false
     10786768730639108688  1152922178327645097     2 false
32 entries were displayed.
 PDFs
PDFs
