volume transition-convert-dir show
Display 7-Mode directories being converted
The volume transition-convert-dir show command displays information about ongoing directory copy conversion operations.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name (privilege: advanced)-
Displays summary information about the ongoing copy conversions of directories for the volumes in the specified Vserver.
 [-volume <volume name>]- Volume Name (privilege: advanced)-
Displays summary information about the ongoing copy conversions of directories that are occurring on the specified volume.
 [-path <text>]- Directory Being Converted (privilege: advanced)-
Displays summary information for the ongoing copy conversions of directories that have the specified directory path to convert.
 [-job-id <integer>]- Convert Job ID (privilege: advanced)-
Displays summary information for the ongoing copy conversions of directories that have the specified job ID.
 [-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}]- Operation State (privilege: advanced)-
Displays summary information for the copy conversions of directories that have the specified job state.
 [-bytes-total <integer>]- Bytes Total (privilege: advanced)-
Displays summary information for copy conversions which have the estimated number of bytes of directory content to convert.
 [-bytes-completed <integer>]- Bytes Completed (privilege: advanced)-
Displays summary information for copy conversions which have the estimated number of bytes of directory content that have completed conversion. The value of this field will be updated approximately once per minute.
The following example illustrates how to show directory conversions for a volume:
cluster1::*> volume transition-convert-dir show -volume vol1 Vserver Volume Convert Job ID Directory-path State --------- --------- ---------------- ---------------- ------------ vs0 vol1 151 /data/large_dir Running
