ONTAP commands
volume transition-convert-dir show
Display 7-Mode directories being converted
The volume transition-convert-dir show command displays information about ongoing directory copy conversion operations.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name (privilege: advanced)
Displays summary information about the ongoing copy conversions of directories for the volumes in the specified Vserver.
[-volume <volume name>] - Volume Name (privilege: advanced)
Displays summary information about the ongoing copy conversions of directories that are occurring on the specified volume.
[-path <text>] - Directory Being Converted (privilege: advanced)
Displays summary information for the ongoing copy conversions of directories that have the specified directory path to convert.
[-job-id <integer>] - Convert Job ID (privilege: advanced)
Displays summary information for the ongoing copy conversions of directories that have the specified job ID.
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}] - Operation State (privilege: advanced)
Displays summary information for the copy conversions of directories that have the specified job state.
[-bytes-total <integer>] - Bytes Total (privilege: advanced)
Displays summary information for copy conversions which have the estimated number of bytes of directory content to convert.
[-bytes-completed <integer>] - Bytes Completed (privilege: advanced)
Displays summary information for copy conversions which have the estimated number of bytes of directory content that have completed conversion. The value of this field will be updated approximately once per minute.
The following example illustrates how to show directory conversions for a volume:
cluster1::*> volume transition-convert-dir show -volume vol1
Vserver    Volume    Convert Job ID   Directory-path   State
vs0        vol1                   151 /data/large_dir       Running
