vserver cifs group-policy restricted-group show-applied
Show the applied restricted-group settings.
The vserver cifs group-policy restricted-group show-applied command displays settings of all the restricted groups applied to a Vserver.
If you do not specify any parameters, the command displays the following information about all the restricted groups applied to all the Vservers in the cluster.
Group Policy Name: Specifies the name of the group policy.
Version: Specifies the version of the group policy.
Link: Specifies the level in which the group policy is configured. Possible values are:
Local: Group policy is configured in Data ONTAP.
Site: Group policy is configured at the site level in the Domain Controller.
Domain: Group policy is configured at the domain level in the Domain Controller.
OrganizationalUnit: Group policy is configured at the OU level in the Domain controller.
RSOP: Resultant set of policies derived from all the group policies defined at various levels.
Group Name: Specifies the name of a restricted group.
Members: Specifies users and groups who belong to and who do not belong to the restricted group.
MemberOf: Specifies list of groups to which the restricted group is added. A group can be a member of groups other than the groups listed here.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If this parameter is specified, the command displays the restricted-group information that has been applied to the specified Vserver.
[-index <integer>]- Index-
If this parameter is specified, the command displays the specified index for the group policy in the restricted group. The restricted-group information for the group policy at the specified index.
[-group-name <text>]- Group Name-
If this parameter is specified, the command displays the restricted-group information for the specified group name.
[-group-policy-name <text>]- Group Policy Name-
If this parameter is specified, the command displays the restricted-group information for the specified group policy name.
[-uuid <UUID>]- UUID-
If this parameter is specified, the command displays the restricted-group information for the specified UUID of the group policy.
[-version <integer>]- Version-
If this parameter is specified, the command displays the restricted-group information for the specified version of the group policy.
[-link <gpo-link>]- Link Type-
If this parameter is specified, the command displays the restricted-group information for the specified link for the group policy.
[-members <gpoUserGroup>,…]- Members, List of Users/groups-
If this parameter is specified, the command displays the restricted-group information for the specified members of users and groups.
[-member-of <gpoUserGroup>,…]- MemberOf, List of Groups-
If this parameter is specified, the command displays the restricted-group information for the specified member of the group.
The following example displays information about all restricted groups that have been applied to a Vserver.
cluster1::> vserver cifs group-policy restricted-group show-applied
Vserver: vs_1
Group Policy Name: gpo1
Version: 16
Link: OrganizationalUnit
Group Name: grp1
Members: usr1
MemberOf: GPO\g9
Group Policy Name: Resultant Set of Policy
Version: 0
Link: RSOP
Group Name: grp1
Members: usr1
MemberOf: GPO\g9
