      security anti-ransomware volume attack generate-report
Generates Report File of the Suspected Attack on the Volume
The anti-ransomware volume attack generate-report command copies the report file to the given path.
-vserver <vserver name>- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
 -volume <volume name>- Volume Name-
This parameter specifies the name of the volume on which anti-ransomware feature is enabled.
 -dest-path <[vserver:]volume/path/to/filename>- Destination path under the volume to copy the file-
This parameter specifies the path where requested file is to be copied.
The following example displays command output:
node::*> security anti-ransomware volume attack generate-report -volume vol1 -dest-path vs1:vol1/ Report "report_file_vs1vol1_30-03-2021_16-11-38" available at path "vs1:vol1/".
