The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security anti-ransomware volume attack generate-report
PDF of this doc site
Creating your file...
Your file is ready
Generates Report File of the Suspected Attack on the Volume
The anti-ransomware volume attack generate-report
command copies the report file to the given path.
-vserver <vserver name>
- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This parameter specifies the name of the volume on which anti-ransomware feature is enabled.
-dest-path <[vserver:]volume/path/to/filename>
- Destination path under the volume to copy the file-
This parameter specifies the path where requested file is to be copied.
The following example displays command output:
node::*> security anti-ransomware volume attack generate-report -volume vol1 -dest-path vs1:vol1/ Report "report_file_vs1vol1_30-03-2021_16-11-38" available at path "vs1:vol1/".
