security anti-ransomware volume attack generate-report
Generates Report File of the Suspected Attack on the Volume
The anti-ransomware volume attack generate-report command copies the report file to the given path. The report file is not an exhaustive list of all suspected files during the attack, since the maximum number of entries allowed per file extension is 20.
-vserver <vserver name>- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name-
This parameter specifies the name of the volume on which anti-ransomware feature is enabled.
-dest-path <sub dir>- Destination path under the volume to copy the report file-
This parameter specifies the path where requested file is to be copied.
The following example displays command output:
node::*> security anti-ransomware volume attack generate-report -volume vol1 -dest-path vs1:vol1/ Report "report_file_vs1vol1_30-03-2021_16-11-38" available at path "vs1:vol1/".
