storage array port show
Display information about a storage array's target ports.
The storage array port show command displays all the target ports known to the cluster for a given storage array (if an array name is specified) or for all storage arrays if no storage array name is specified. Target ports remain in the database as part of an array profile unless you explicitly remove them from the database.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-name <text>] - Name
Selects the array ports that match this parameter value. The storage array name is either generated by Data ONTAP or assigned by the user.
[-wwnn <text>] - WWNN
[-wwpn <text>] - WWPN
[-max-queue-depth <integer>] - Target Port Queue Depth
[-node {<nodename>|local}] - Controller Name
[-initiator-port <text>,…​] - Initiator Port
[-average-dynamic-queue-depth <integer>,…​] - Average Dynamic Queue Depth (privilege: advanced)
The average value of the dynamic target port queue depth.
[-average-latency-per-iop <integer>,…​] - Average Latency Per IOP
Selects the array ports that match this parameter value (average latency per I/O performed in microseconds).
[-average-pending <integer>,…​] - Average Pending (privilege: advanced)
Selects the array ports that match this parameter value (average over time of how many commands are on the outstanding queue).
[-average-waiting <integer>,…​] - Average Waiting (privilege: advanced)
Selects the array ports that match this parameter value (average over time of how many commands are on the waiting queue).
[-connection-type {direct|fabric|ISCSI}] - Connection Type
Selects the array ports that match this parameter value (type of connection between the controller and the back end storage).
[-dynamic-queue-depth <integer>,…​] - Dynamic Queue Depth (privilege: advanced)
Current dynamic target port queue depth, the maximum number of commands allowed outstanding.
[-max-pending <integer>,…​] - Max Pending (privilege: advanced)
Selects the array ports that match this parameter value (largest number of commands observed on the outstanding queue).
[-max-waiting <integer>,…​] - Max Waiting (privilege: advanced)
Selects the array ports that match this parameter value (largest number of commands observed on the waiting queue).
[-path-link-errors <integer>,…​] - Link Error count on path
[-percent-busy <integer>,…​] - Percent Busy
Selects the array ports that match this parameter value (percentage of time I/Os are outstanding on the port).
[-percent-waiting <integer>,…​] - Percent Waiting
Selects the array ports that match this parameter value (percentage of time there are I/Os waiting on the throttle list on the target port).
[-switch-port <text>] - Switch Port
Selects the array ports that match this parameter value (for fabric attached connections, the switch port the array target port is connected to; N/A for direct attached).
[-target-io-kbps <integer>,…​] - Kbytes of I/O per second to Target (Rolling Average)
[-target-iops <integer>,…​] - Number of IOPS to Target (Rolling Average)
[-target-lun-in-use-count <integer>,…​] - Target LUN In Use Count
Selects the array ports that match this parameter value (number of IN-USE disks on this target port).
[-target-port-speed <text>] - Target Port Speed
Selects the array ports that match this parameter value (speed that the target port has negotiated with its connected switch port, or initiator port if direct attached).
[-utilization-policy {normal|defer}] - Utilization Policy
The policy used when sending I/O to an array target port when it reaches maximum queue depth. Possible values are:
  • normal - This policy aggressively competes for target port resources, in effect competing with other hosts. (default)
  • defer - This policy does not aggressively compete for target port resources, in effect deferring to other hosts.
The example below displays the port information for a single port.
cluster1::> storage array port show -wwpn 50060e80004291c0
Array Name: HITACHI_DF600F_1
WWNN: 50060e80004291c0
WWPN: 50060e80004291c0
Connection Type: fabric
Switch Port: vgbr300s89:9
Link Speed: 4 GB/s
Max Queue Depth: 1024
Utilization Policy: normal
                              LUN                                        Link
Node              Initiator  Count   IOPS    KB/s    %busy    %waiting   Errs
     vnv3070f20a         0b      2       0       0        0           0     0
     vnv3070f20b         0b      2       0       0        0           0     0
