volume rebalance show
Display a list of volume capacity rebalancing operations on FlexGroup volumes
The volume rebalance show command displays information about volume capacity rebalancing operations on FlexGroup volumes.
The volume rebalance show command is only supported on FlexGroup volumes and constituents. The command displays rebalancing information for volumes. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all volumes:
Vserver name
Volume name
Rebalancing state
Total size
Used size for calculating imbalance
Size used by Snapshot copies
Target used size
Imbalance size
Imbalance percent
To display detailed rebalancing information about each FlexGroup volume or constituent, run the command with the -instance parameter. The detailed view provides the following information for FlexGroup volumes:
Vserver name
Volume name
Is constituent
Rebalance state
Total size
Imbalance size
Imbalance percentage
Maximum constituent imbalance percentage
Rebalance start time
Rebalance stop time
Rebalance runtime
Rebalance maximum runtime
Maximum imbalance threshold per constituent
Minimum imbalance threshold per constituent
Maximum files moved per constituent
Minimum file size
Exclude files stuck in snapshot copies
Rebalance notice messages
The detailed view provides the following information for FlexGroup constituents:
Vserver name
Volume name
Is constituent
Rebalance state
Total size
Constituent target used size
Imbalance size
Moved data size
Rebalance stop time
Rebalance runtime
Minimum file size
You can specify parameters from the above list to display information. For example, to display information only about currently running rebalancing operations, run the command with the -state rebalancing parameter
[-fields <fieldname>,…] -
If you specify the
[-config ] -
If this parameter is specified, the command displays the following information:
max-runtime
max-threshold
min-threshold
max-file-moves
min-file-size
exclude-snapshots
[-time ] -
start-time
runtime
max-runtime
[-instance ]} -
If this parameter is specified, the command displays the additional detailed information described above.
[-vserver <vserver name>]- Vserver Name-
Selects information about volume capacity rebalancing operations on FlexGroup volumes in the specified Vserver.
[-volume <volume name>]- Volume Name-
Selects information about volume capacity rebalancing operations on the specified FlexGroup volume.
[-is-constituent {true|false}]- Is Constituent-
If specified, the command displays information about volume capacity rebalancing operations on constituents.
[-state {idle|starting|rebalancing|rebalancing-source|rebalancing-dest|scanning|stopping|paused|not-running|unknown}]- Rebalance State-
Selects information about volume capacity rebalancing operations with the specified state. While a FlexGroup volume is rebalancing, every constituent will have a rebalancing engine that can either be scanning the filesystem for space usage and files to move, actively moving files or temporarily doing neither. If one or more constituents has a state of
rebalancing-sourceorrebalancing-dest, then files are being moved to rebalance the FlexGroup. If no files are being moved, more information about what the rebalancing engine is doing for each constituent is available using the (privilege: advanced)volume rebalance show -instancecommand. The following values apply to FlexGroup volumes.-
not-running- Capacity rebalancing is not running on the volume. This will only change when the user explicitly starts rebalancing. -
idle- Capacity rebalancing is running, however, no active scanning or file movement is currently happening. -
starting- The capacity rebalancing operation is starting on the volume. -
rebalancing- Volume capacity rebalancing is running on the volume. -
paused- The capacity rebalancing operation is paused on the volume. -
stopping- The capacity rebalancing operation is stopping on the volume. -
unknown- The system was unable to determine the rebalancing state for the volume.
[-notices <text>,…]- Rebalance Notice Messages-
Selects information about volume capacity rebalancing operations with the specified notice messages.
[-total {<integer>[KB|MB|GB|TB|PB]}]- Total Size-
Selects information about volume capacity rebalancing operations with the specified total size.
[-used-for-imbalance {<integer>[KB|MB|GB|TB|PB]}]- Used Size for Calculating Imbalance-
Selects information about volume capacity rebalancing operations with the specified used size for calculating imbalance. This is calculated by subtracting the size used by Snapshot copies, the size of files pending deletion and the size used by filesystem metadata from the volume's used size.
[-size-used-by-snapshots {<integer>[KB|MB|GB|TB|PB]}]- Volume Size Used by Snapshot Copies-
Selects information about volume capacity rebalancing operations with the specified volume size used by Snapshot copies.
[-target-used {<integer>[KB|MB|GB|TB|PB]}]- Constituent Target Used Size-
Selects information about volume capacity rebalancing operations with the specified target used size on a constituent. Represents the average used size among all constituents.
[-imbalance-size {<integer>[KB|MB|GB|TB|PB]}]- Imbalance Size-
Selects information about volume capacity rebalancing operations with the specified imbalance size.
[-imbalance-percent <percent_no_limit_signed>]- Imbalance Percentage-
Selects information about volume capacity rebalancing operations with the specified imbalance percentage.
[-data-moved {<integer>[KB|MB|GB|TB|PB]}]- Moved Data Size-
Selects information about volume capacity rebalancing operations with the specified moved data size.
[-max-constituent-imbalance-percent <percent_no_limit>]- Maximum Constituent Imbalance Percentage-
Selects information about volume capacity rebalancing operations with the specified maximum constituent imbalance percentage. Represents the imbalance percentage of the constituent most out of balance.
[-start-time <Date>]- Rebalance Start Time-
Selects information about volume capacity rebalancing operations with the specified start time.
[-stop-time <Date>]- Rebalance Stop Time-
Selects information about volume capacity rebalancing operations with the specified stop time.
[-runtime <time_interval>]- Rebalance Runtime-
Selects information about volume capacity rebalancing operations with the specified run time.
[-max-runtime <time_interval>]- Rebalance Maximum Runtime-
Selects information about volume capacity rebalancing operations with the specified maximum run time. Represents the maximum amount of time a rebalancing operation can run for before stopping.
[-max-threshold <percent>]- Maximum Imbalance Threshold per Constituent-
Selects information about volume capacity rebalancing operations with the specified maximum threshold. Represents the acceptable imbalance threshold beyond which rebalancing should be started on that constituent in the FlexGroup volume.
[-min-threshold <percent>]- Minimum Imbalance Threshold per Constituent-
Selects information about volume capacity rebalancing operations with the specified minimum threshold. Represents the minimum imbalance threshold at which rebalancing is stopped for the constituent in the FlexGroup volume.
[-max-file-moves <integer>]- Maximum Concurrent File Moves per Constituent-
Selects information about volume capacity rebalancing operations with the specified maximum concurrent file moves. Represents the maximum number of concurrent file moves allowed per constituent.
[-min-file-size {<integer>[KB|MB|GB|TB|PB]}]- Minimum File Size-
Selects information about volume capacity rebalancing operations with the specified minimum file size. Represents the minimum size of file to be considered for rebalancing a constituent in a FlexGroup volume.
[-exclude-snapshots {true|false}]- Exclude Files Stuck in Snapshot Copies-
Selects information about volume capacity rebalancing operations with the specified excluding snapshot flag. Represents whether or not files that are in Snapshot copies as candidates for rebalancing are ignored.
The following example displays rebalancing information about all FlexGroup volumes on Vserver "vs0":
cluster::> volume rebalance show -vserver vs0
Vserver: vs0
Projected
AFS Target Imbalance
Volume State Total Used Used Size %
fg1 rebalancing 400MB 117.7MB - 176KB 0%
fg2 not-running 800MB 115.0MB - 8KB 0%
2 entries were displayed.
The following example displays rebalancing information about all FlexGroup constituents on Vserver "vs0":
cluster::> volume rebalance show -vserver vs0 -is-constituent True
Vserver: vs0
Projected
fg1__0001 idle 200MB 59.03MB 58.86MB 176KB 0%
fg1__0002 idle 200MB 58.69MB 58.86MB -172KB 0%
fg2__0001 not-running 200MB 28.77MB 28.76MB 4KB 0%
fg2__0002 not-running 200MB 28.76MB 28.76MB -4KB 0%
fg2__0003 not-running 200MB 28.77MB 28.76MB 4KB 0%
fg2__0004 not-running 200MB 28.76MB 28.76MB -4KB 0%
6 entries were displayed.
The following example displays detailed rebalancing information about a specific FlexGroup volume "fg1" on Vserver "vs0":
cluster::> volume rebalance show -vserver vs0 -volume fg1 -instance
Vserver Name: vs0
Volume Name: fg1
Is Constituent: false
Rebalance State: not-running
Rebalance Notice Messages: -
Total Size: 400MB
Projected AFS Used Size: 117.7MB
Volume Size Used by Snapshot Copies: 10.57MB
Constituent Target Used Size: -
Imbalance Size: 176KB
Imbalance Percentage: 0%
Moved Data Size: -
Maximum Constituent Imbalance Percentage: 0%
Rebalance Start Time: Fri Mar 25 17:26:09 2022
Rebalance Stop Time: Fri Mar 25 17:29:29 2022
Rebalance Runtime: 0h3m20s
Rebalance Maximum Runtime: 0h3m20s
Maximum Imbalance Threshold per Constituent: 20%
Minimum Imbalance Threshold per Constituent: 5%
Maximum Concurrent File Moves per Constituent: 25
Minimum File Size: 4KB
Exclude Files Stuck in Snapshot Copies: true
The following example displays detailed rebalancing information about a specific FlexGroup constituent "fg1__0001" on Vserver "vs0":
cluster::> volume rebalance show -vserver vs0 -volume fg1__0001 -instance -is-constituent True
Vserver Name: vs0
Volume Name: fg1__0001
Is Constituent: true
Total Size: 200MB
Projected AFS Used Size: 59.04MB
Volume Size Used by Snapshot Copies: 5.46MB
Constituent Target Used Size: 58.86MB
Moved Data Size: 0B
Maximum Constituent Imbalance Percentage: -
