ONTAP commands
system switch ethernet log collect
Collect Ethernet switch log via openSSH.
The system switch ethernet log collect command initiates the collection of an Ethernet switch log for the specified Ethernet switch via OpenSSH.
Note Log files are removed during takeover or giveback operations.
-device <text> - Switch Name
Specifies the Ethernet switch device for which the log collection is being made.
cluster1::> system switch ethernet log collect -device cluster-sw1
