security session limit modify
Modify default session limit
This command allows modification of a default management session limit.
-interface {cli|ontapi|rest} - Interface
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-category {application|location|request|user|vserver} - Category
The session type for this default limit. The following categories are supported: application, location, request, user, Vserver.
[-max-active-limit <integer>] - Max-Active Limit
The maximum number of concurrent sessions allowed for this interface and category.
The following example illustrates modifying the default limit for CLI management sessions from the same location.
cluster1::> security session limit modify -interface cli -category location -max-active-limit 4
