The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
metrocluster config-replication cluster-storage-configuration modify
PDF of this doc site
Creating your file...
Your file is ready
Modify MetroCluster storage configuration information
The metrocluster config-replication cluster-storage-configuration modify
command modifies the configuration of storage used for configuration replication.
[-disallowed-aggregates <aggregate name>,…]
- Disallowed Aggregates (privilege: advanced)-
Use this parameter to set the list of storage aggregates that are not available to host storage for configuration replication.
The following example disallows two aggregates named aggr1
and aggr2
cluster1::*> metrocluster config-replication cluster-storage-configuration modify -disallowed-aggregates aggr1,aggr2
