security tpm show
Display the status of TPM
This command displays information about the status of the Trusted Platform Module(TPM) device. By default, this command displays the following information:
Node name
Availability of the device
State of the device, if available
Firmware version
Firmware upgrade counter
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the nodes that match this parameter value
 [-is-available {yes|no}]- Is TPM Available?-
Selects the nodes that match this parameter value.
yes - The TPM device is mounted and available.
no - The node does not support a TPM.
 [-is-active {yes|no}]- Is TPM Active?-
yes - The TPM device is available and active.
no - if
-is-availableparameter isyes, the TPM device is mounted and available but is not responding to TPM commands.
 [-version <text>]- Firmware Version-
Selects the nodes that match this firmware version.
 [-upgrade-count <integer>]- Firmware Counter-
Selects the nodes that match the given number of firmware upgrade tries left.
 [-sym-key-size <integer>]- Size of Primary Symmetric Key-
Selects the nodes that match the given symmetrice key size for the primary symmetric key.
cluster1::> security tpm show
                                       Firmware  Firmware
Node             Available?  Active?   Version    Counter
node1            yes         yes       2.5             64
node2            yes         yes       2.5             64
2 entries were displayed.
