vserver cifs security show
Display CIFS security settings
The vserver cifs security show command displays information about CIFS server security settings.
{ [-fields <fieldname>,…​]
If you specify the -fields parameter, the command only displays the fields that you specify.
| [-instance ] }
[-vserver <vserver name>] - Vserver
This parameter specifies the name of the Vserver whose CIFS security settings you want to display.
[-kerberos-clock-skew <integer>] - Maximum Allowed Kerberos Clock Skew
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos ticket clock skew.
[-kerberos-ticket-age <integer>] - Kerberos Ticket Lifetime
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos ticket age.
[-kerberos-renew-age <integer>] - Maximum Kerberos Ticket Renewal Days
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos renewal age.
[-kerberos-kdc-timeout <integer>] - Timeout for Kerberos KDC Connections (Secs)
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos KDC timeout.
[-realm <text>] - Kerberos Realm
If this parameter is specified, the command displays information only about the security settings that match the specified Kerberos realm.
[-kdc-ip <text>,…​] - KDC IP Address
If this parameter is specified, the command displays information only about the security settings that match the specified KDC IP address.
[-kdc-name <text>,…​] - KDC Name
If this parameter is specified, the command displays information only about the security settings that match the specified KDC name.
[-site <text>,…​] - KDC Site
If this parameter is specified, the command displays information only about the security settings that match the specified Windows site.
[-is-signing-required {true|false}] - Require Signing for Incoming CIFS Traffic
This parameter specifies whether signing is required for incoming CIFS traffic. If this parameter is specified, the command displays information only about the security settings that match the specified value for is-signing-required.
[-is-password-complexity-required {true|false}] - Require Password Complexity for Local User Accounts
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where password complexity for local user accounts is required. If set to false , the command displays security configuration information for CIFS servers where password complexity for local user accounts is not required.
[-use-start-tls-for-ad-ldap {true|false}] - Use start_tls for AD LDAP Connections
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where Start TLS is used for communication with the AD LDAP Server. If set to false , the command displays CIFS security configuration information only for CIFS servers where Start TLS is not used for communication with the AD LDAP Server.
[-is-aes-encryption-enabled {true|false}] - (DEPRECATED)-Is AES-128 and AES-256 Encryption for Kerberos Enabled
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where AES-128 and AES-256 encryption types for Kerberos are enabled. If set to false , the command displays security configuration information for CIFS servers where AES-128 and AES-256 encryption types for Kerberos are disabled.
Note This parameter is deprecated and may be removed from a future release.
[-lm-compatibility-level {lm-ntlm-ntlmv2-krb|ntlm-ntlmv2-krb|ntlmv2-krb|krb}] - LM Compatibility Level
If this parameter is specified, the command displays information only about the security settings that match the specified LM compatibility level.
[-is-smb-encryption-required {true|false}] - Require SMB Encryption for Incoming CIFS Traffic
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where SMB encryption is required. If set to false , the command displays security configuration information for CIFS servers where SMB encryption is not required.
[-session-security-for-ad-ldap {none|sign|seal}] - Client Session Security
If this parameter is set to seal , the command displays CIFS security configuration information only for CIFS servers where both signing and sealing are required for LDAP communications. If set to sign , the command displays security configuration information for CIFS servers where only signing is required for LDAP communications. If set to none , the command displays security configuration information for CIFS servers where no security is required for LDAP communications.
[-smb1-enabled-for-dc-connections {false|true|system-default}] - (DEPRECATED)-SMB1 Enabled for DC Connections
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where SMB1 is enabled for use with connections to domain controllers. If set to false , the command displays security configuration information for CIFS servers where SMB1 is not enabled for use with connections to domain controllers. If set to system-default , the command displays security configuration information for CIFS servers where the system-default setting (SMB1 enabled) is used for connections to domain controllers.
Note This parameter is deprecated because the SMB1 protocol is obsolete and considered insecure. It might be removed in a future release.
[-smb2-enabled-for-dc-connections {false|true|system-default}] - SMB2 Enabled for DC Connections
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where SMB2 is enabled for use with connections to domain controllers. If set to false , the command displays security configuration information for CIFS servers where SMB2 is not enabled for use with connections to domain controllers. If set to system-default , the command displays security configuration information for CIFS servers where the system-default setting (SMB2 enabled) is used for connections to domain controllers.
[-referral-enabled-for-ad-ldap {true|false}] - LDAP Referral Chasing Enabled For AD LDAP Connections
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where LDAP referral is enabled for AD LDAP connections. If set to false , the command displays security configuration information for CIFS servers where LDAP referral is not enabled for AD LDAP connections.
[-use-ldaps-for-ad-ldap {true|false}] - Use LDAPS for Secure Active Directory LDAP Connections
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where LDAPS is used for communication with the AD LDAP Server. If set to false , the command displays CIFS security configuration information only for CIFS servers where LDAPS is not used for communication with the AD LDAP Server.
[-encryption-required-for-dc-connections {true|false}] - Encryption is required for DC Connection
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where encryption is required for use with connections to domain controllers. If set to false , the command displays security configuration information for CIFS servers where encryption is not required for use with connections to domain controllers.
[-aes-enabled-for-netlogon-channel {true|false}] - AES session key enabled for NetLogon channel
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where AES session key is used for Netlogon secure channel. If set to false , the command displays CIFS security configuration information only for CIFS servers where AES session key is not used for Netlogon secure channel.
[-try-channel-binding-for-ad-ldap {true|false}] - Try Channel Binding For AD LDAP Connections
If this parameter is set to true , the command displays CIFS security configuration information only for CIFS servers where channel binding is tried for AD LDAP connections. If set to false , the command displays CIFS security configuration information only for CIFS servers where channel binding is not tried for AD LDAP connections.
[-advertised-enc-types <CIFS Kerberos Encryption Type>,…​] - Encryption Types Advertised to Kerberos
If this parameter is specified, the command displays information only about the security settings that match the specified advertised encryption types.
The following example displays CIFS server security settings.
cluster1::> vserver cifs security show
Vserver: vs1
Kerberos Clock Skew:               3 minutes
                                  Kerberos Ticket Age:               8 hours
                                 Kerberos Renewal Age:               7 days
                                 Kerberos KDC Timeout:               3 seconds
                                  Is Signing Required:            true
                      Is Password Complexity Required:            true
                 Use start_tls For AD LDAP connection:           false
                            Is AES Encryption Enabled:           false
                               LM Compatibility Level:             krb
                           Is SMB Encryption Required:           false
                              Client Session Security:            none
                      SMB1 Enabled For DC Connections:  system-default
                      SMB2 Enabled For DC Connections:  system-default
LDAP Referral Chasing Enabled For AD LDAP Connections:           false
                    Use LDAPS for AD LDAP Connections:            true
               Encryption required For DC Connections:           false
         AES session key enabled for NetLogon channel:           false
          Try Channel Binding For AD LDAP Connections:            true
              Encryption Types Advertised to Kerberos:           des, rc4
The following example displays the Kerberos clock skew for all Vservers.
cluster1::> vserver cifs security show -fields kerberos-clock-skew
vserver kerberos-clock-skew
            vs1     5
