volume create
Create a new volume
The volume create command creates a volume on a specified Vserver and storage aggregates. You can optionally specify the following attributes for the new volume:
Size
State (online, offline, or restricted)
Type (read-write or data-protection)
Export policy
User ID
Group ID
Security style (All volume types: UNIX mode bits, CIFS ACLs, or mixed NFS and CIFS permissions.)
Default UNIX permissions for files on the volume
Language
Junction path
Whether the junction path is active (advanced privilege level or higher only)
Whether the volume is the root volume for its Vserver (advanced privilege level or higher only)
Comment
Whether autosizing is enabled for FlexVols
Maximum size for autosizing FlexVols
Minimum size for autosize
Grow used space threshold percentage for autosize
Shrink used space threshold percentage for autosize
Current mode of operation of volume autosize
Maximum directory size (advanced privilege level or higher only)
Space guarantee style (none or volume)
Space SLO type (none, thick or semi-thick)
Snapshot policy
Snapshot reserve percentage
Use logical space reporting
Use logical space enforcement
Whether the volume create operation runs as a foreground or background process
Caching policy
Encrypt
File system analytics state
Tiering object tags
Key Manager Attribute
SnapLock type
Activity tracking state
-vserver <vserver name>- Vserver Name-
This specifies the Vserver on which the volume is located. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>- Volume Name-
This specifies the name of the volume that is to be created. A volume's name must start with an alphabetic character (a to z or A to Z) and be 197 or fewer characters in length for FlexGroups, and 203 or fewer characters in length for all other volume types. Volume names must be unique within a Vserver.
[-aggregate <aggregate name>]- Aggregate Name -
This specifies the storage aggregate on which the volume is to be created. This parameter only applies to FlexVol volumes.
[-aggr-list <aggregate name>,…]- List of Aggregates for FlexGroup Constituents -
Specifies an array of names of aggregates to be used for FlexGroup constituents. Each entry in the list will create a constituent on the specified aggregate. The root constituent will always be placed on the first aggregate in the list. An aggregate may be specified multiple times to have multiple constituents created on it. This parameter only applies to FlexGroups.
[-aggr-list-multiplier <integer>]- Aggregate List Repeat Count-
Specifies the number of times to iterate over the aggregates listed with the
-aggr-listparameter when creating a FlexGroup. The aggregate list will be repeated the specified number of times. Example:
-aggr-list aggr1,aggr2 -aggr-list-multiplier 2
will cause four constituents to be created in the order aggr1 , aggr2 , aggr1 , aggr2 .
The default value is 4.
[-auto-provision-as <FlexGroup>]- Automatically Provision as Volume of Type -
Use this parameter to automatically select existing aggregates for provisioning FlexGroup volumes. Note that the fastest aggregate type with at least one aggregate on each node of the cluster will be selected. When auto provisioning a FlexGroup volume, the size of the FlexGroup volume should be a minimum of 800 GB per node.
[-support-tiering {true|false}]- Automatically Provision FlexGroup on FabricPools-
This parameter specifies whether or not FabricPools are selected when provisioning a FlexGroup during the protection workflows using the
auto-provision-asparameter. Only FabricPool aggregates are used if this parameter is set to true and only non FabricPool aggregates are used if this parameter is set to false. Tiering support for a FlexGroup can be changed by moving all of the constituents to the required aggregates. The default value isfalseThis parameter only applies to FlexGroups created using the
-auto-provision-asparameter. [-use-mirrored-aggregates {true|false}]- Automatically Provision FlexGroup on Mirrored Aggregates-
Use this parameter to specify whether mirrored aggregates are selected when creating a FlexGroup using the
auto-provision-asparameter. Only mirrored aggregates are used if this parameter is set to true and only unmirrored aggregates are used if this parameter is set to false. Aggregate level mirroring for a FlexGroup can be changed by moving all of the constituents to the required aggregates. The default value istruefor a MetroCluster configuration and isfalsefor a non-MetroCluster configurationThis parameter only applies to FlexGroups created using the
-auto-provision-asparameter. [-encryption-type {none|volume|aggregate}]- Encryption Type-
Use this parameter to specify the encryption-type while creating a FlexGroup using the
auto-provision-asparameter. If the value isnone, the FlexGroup created will be unencrypted. If the value isvolume, the FlexGroup created will be of type NVE (NetApp Volume Encryption) and if the value isaggregate, the FlexGroup created will be of type NAE (NetApp Aggregate Encryption).This parameter only applies to FlexGroups created using the
-auto-provision-asparameter. [-nodes {<nodename>|local}]- List of Nodes Hosting the Volume }-
Specifies an array of node names to be used for provisioning the FlexGroup. If an array of node names is specified, only aggregates from the specified nodes will be considered for provisioning. If no value is specified, all nodes in the cluster will be used.
[-size {<integer>[KB|MB|GB|TB|PB]}]- Volume Size-
This optionally specifies the size of the volume. The size is specified as a number followed by a unit designation: k (kilobytes), m (megabytes), g (gigabytes), or t (terabytes). If the unit designation is not specified, bytes are used as the unit, and the specified number is rounded up to the nearest 4 KB. The minimum size for a FlexVol volume is 20 MB. The minimum size for a volume guaranteed FlexGroup is 20 MB per constituent. The minimum size for a none guaranteed FlexGroup is 200 MB per constituent. However, the recommended size for all FlexGroups is a minimum of 100 GB per constituent. For all volumes, the default size is set to the minimum size. The volume's maximum size is limited by the platform maximum. If the volume's guarantee is set to
volume, the volume's maximum size can also be limited by the available space in the hosting aggregates. Volumes can be increased and decreased in size with the volume modify command. The maximum number of files a volume is configured for is listed under "Total Files" when running the command volume show-instance. [-state {online|restricted|offline|force-online|force-offline|mixed}]- Volume State-
This optionally specifies the volume's state. A restricted volume does not provide client access to data but is available for administrative operations.
The mixedstate applies to FlexGroups only and cannot be specified as a target state. [-policy <text>]- Export Policy-
This optionally specifies the ID number of the export policy associated with the volume. For information on export policies, see the documentation for the vserver export-policy create command. FlexGroups do not support policies that allow NFSv4 protocol access.
[-user <user name>]- User ID-
This optionally specifies the name or ID of the user that is set as the owner of the volume's root.
[-group <group name>]- Group ID-
This optionally specifies the name or ID of the group that is set as the owner of the volume's root.
[-security-style <security style>]- Security Style-
This optionally specifies the security style for the volume. Possible values include
unix(for UNIX mode bits),ntfs(for CIFS ACLs),mixed(for mixed NFS and CIFS permissions) andunified(for mixed NFS and CIFS permissions with unified ACLs). Regardless of the security style, both NFS and CIFS clients can read from and write to the volume. [-unix-permissions <unix perm>]- UNIX Permissions-
This optionally specifies the default UNIX permissions for files on the volume. Specify UNIX permissions either as a four-digit octal value (for example, 0700) or in the style of the UNIX
lscommand (for example, -rwxr-x---). For information on UNIX permissions, see the UNIX or Linux documentation. The default setting is 0755 or ---rwxr-xr-x. [-junction-path <junction path>]- Junction Path-
This optionally specifies the volume's junction path. The junction path name is case insensitive and must be unique within a Vserver's namespace.
[-junction-active {true|false}]- Junction Active (privilege: advanced)-
This optionally specifies whether the volume's junction path is active. The default setting is
true. If the junction path is inactive, the volume does not appear in the Vserver's namespace. This parameter is available only at the advanced privilege level and higher. [-vsroot {true|false}]- Vserver Root Volume (privilege: advanced)-
This optionally specifies whether the volume is the root volume of its Vserver. The default setting is
false. This parameter is not supported on FlexGroups. [-comment <text>]- Comment-
This optionally specifies a comment for the volume.
[-max-autosize {<integer>[KB|MB|GB|TB|PB]}]- Maximum Autosize-
This parameter allows the user to specify the maximum size to which a volume can grow. The default for volumes is 120% of the volume size. If the value of this parameter is invalidated by manually resizing the volume, the maximum size is reset to 120% of the volume size. The value for
-max-autosizecannot be set larger than the platform-dependent maximum volume size. If you specify a larger value, the value of-max-autosizeis automatically reset to the supported maximum without returning an error. [-min-autosize {<integer>[KB|MB|GB|TB|PB]}]- Minimum Autosize-
This parameter specifies the minimum size to which the volume can automatically shrink. If the volume was created with the
grow_shrinkautosize mode enabled, then the default minimum size is equal to the initial volume size. If the value of the-min-autosizeparameter is invalidated by a manual volume resize, the minimum size is reset to the volume size. [-autosize-grow-threshold-percent <percent>]- Autosize Grow Threshold Percentage-
This parameter specifies the used space threshold for the automatic growth of the volume. When the volume’s used space becomes greater than this threshold, the volume will automatically grow unless it has reached the maximum autosize.
[-autosize-shrink-threshold-percent <percent>]- Autosize Shrink Threshold Percentage-
This parameter specifies the used space threshold for the automatic shrinking of the volume. When the amount of used space in the volume drops below this threshold, the volume will shrink unless it has reached the specified minimum size.
[-autosize-mode {off|grow|grow_shrink}]- Autosize Mode-
This parameter specifies the autosize mode for the volume. The supported autosize modes are:
off- The volume will not grow or shrink in size in response to the amount of used space. -
grow- The volume will automatically grow when used space in the volume is above the grow threshold. -
grow_shrink- The volume will grow or shrink in size in response to the amount of used space.
By default,
-autosize-modeisofffor new volumes, except for data protection mirrors, for which the default value isgrow_shrink. Thegrowandgrow_shrinkmodes work together with Snapshot autodelete to automatically reclaim space when a volume is about to become full. The volume parameter-space-mgmt-try-firstcontrols the order in which these two space reclamation policies are attempted. -
[-files-set-maximum {true|false}]- Set Total Files (for user-visible data) to the Highest Value that the Volume can Hold (privilege: advanced)-
This optionally specifies whether the volume's total number of files will be set to the highest possible value. By default, it is
false. Iftrue, the volume's total number of files is set to the highest value that the volume can hold. [-maxdir-size {<integer>[KB|MB|GB|TB|PB]}]- Maximum Directory Size (privilege: advanced)-
This optionally specifies the maximum directory size. The default maximum directory size is model-dependent and optimized for the size of system memory.
[-space-slo {none|thick|semi-thick}]- Space SLO -
This optionally specifies the Service Level Objective for space management (the space SLO setting) for the volume. The space SLO value is used to enforce volume settings so that sufficient space is set aside to meet the space SLO. The default setting is
none. There are three supported values:none,thickandsemi-thick.-
none: The value ofnonedoes not provide any guarantee for overwrites or enforce any restrictions. It should be used if the admin plans to manually manage space consumption in the volume and aggregate, and out of space errors. -
thick: The value ofthickguarantees that the hole fills and overwrites to space-reserved files in this volume will always succeed by reserving space. To meet this space SLO, the following volume-level settings are automatically set and cannot be modified: -
Space Guarantee:
volume- The entire size of the volume is preallocated in the aggregate. Changing the volume'sspace-guaranteetype is not supported. -
Fractional Reserve:
100- 100% of the space required for overwrites is reserved. Changing the volume'sfractional-reservesetting is not supported. -
semi-thick: The value ofsemi-thickis a best-effort attempt to ensure that overwrites succeed by restricting the use of features that share blocks and auto-deleting backups and Snapshot copies in the volume. To meet this space SLO, the following volume-level settings are automatically set and cannot be modified: -
Space Guarantee:
Fractional Reserve:
0- No space will be reserved for overwrites by default. However, changing the volume'sfractional-reservesetting is supported. Changing the setting to 100 means that 100% of the space required for overwrites is reserved. -
Snapshot Autodelete:
enabled- Automatic deletion of Snapshot copies is enabled to reclaim space. To ensure that the overwrites can be accommodated when the volume reaches threshold capacity, the following volume Snapshot autodelete parameters are set automatically to the specified values and cannot be modified: -
enabled:true -
commitment:destroy -
trigger:volume -
defer-delete:none -
destroy-list:vol_clone,lun_clone,file_clone,cifs_shareIn addition, with a value of ``_semi-thick_`` , the following technologies are not supported for the volume:
File Clones with autodelete disabled: Only full file clones of files, LUNs or NVMe namespaces that can be autodeleted can be created in the volume. The use of
autodeletefor file clone create is required. -
Partial File Clones: Only full file clones of files or LUNs that can be autodeleted can be created in the volume. The use of
rangefor file clone create is not supported. -
Volume Efficiency: Enabling volume efficiency is not supported to allow autodeletion of Snapshot copies.
[-s, -space-guarantee {none|volume}]- Space Guarantee Style -
This optionally specifies the space guarantee style for the volume. A value of
volumereserves space on the aggregates for the entire volume. A value ofnonereserves no space on the aggregates, meaning that writes can fail if an aggregate runs out of space. Because CIFS does not handle out-of-space conditions, do not use the valuenoneif the volume is accessible to CIFS clients. The default setting for the volumes on All Flash FAS systems isnone, otherwise the default setting isvolume. Thefilesetting is no longer supported. [-type {RW|DP}]- Volume Type }-
This optionally specifies the volume's type, either read-write (RW) or data-protection (DP). If you do not specify a value for this parameter, a RW volume is created by default.
[-percent-snapshot-space <percent>]- Space Reserved for Snapshot Copies-
This optionally specifies the amount of space that is reserved in the volume for Snapshot copies. The default setting is 5 percent, except for data protection mirrors for which the default is 0 percent.
[-snapshot-policy <snapshot policy>]- Snapshot Policy-
This optionally specifies the Snapshot policy for the volume. The default is the Snapshot policy for all volumes on the Vserver, as specified by the
-snapshot-policyparameter of the vserver create and vserver modify commands. The schedules associated with thesnapshot-policyfor a FlexGroup cannot have an interval shorter than 30 minutes. [-language <Language code>]- Language-
This optionally specifies the language encoding setting for the volume. By default, the volume inherits the Vserver language encoding setting.
You cannot modify the language encoding setting of a volume. [-foreground {true|false}]- Foreground Process-
This specifies whether the operation runs in the foreground. The default setting is
true(the operation runs in the foreground). When set to true, the command will not return until the operation completes. This parameter applies only to FlexGroups. For FlexVol volumes, the command always runs in the foreground. [-nvfail {on|off}]- NVFAIL Option-
Setting this optional parameter to true causes the volume to set the in-nvfailed-state flag to true, if committed writes to the volume are lost due to a failure. The in-nvfailed-state flag fences the volume from further data access and prevents possible corruption of the application data. Without specifying a value, this parameter is automatically set to false.
[-constituent-role <Constituent Roles>]- Constituent Volume Role-
This parameter is no longer supported.
[-qos-policy-group <text>]- QoS Policy Group Name -
This optional parameter specifies which QoS policy group to apply to the volume. This policy group defines measurable service level objectives (SLOs) that do not adjust based on the volume allocated space or used space. If you do not assign a policy group to a volume, the system will not monitor and control the traffic to it.
[-qos-adaptive-policy-group <text>]- QoS Adaptive Policy Group Name } -
This optional parameter specifies which QoS adaptive policy group to apply to the volume. This policy group defines measurable service level objectives (SLOs) and Service Level Agreements (SLAs) that adjust based on the volume allocated space or used space.
[-caching-policy <text>]- Caching Policy Name-
This optionally specifies the caching policy to apply to the volume. A caching policy defines how the system caches this volume's data in a Flash Pool aggregate or Flash Cache modules. If a caching policy is not assigned to this volume, the system uses
autoas the default caching policy.Both metadata and user data are eligible for caching. Metadata consists of directories, indirect blocks and system metafiles. They are eligible for read caching only. When a random write pattern is detected on user data, the first such write is eligible for read caching while all subsequent overwrites are eligible for write caching. The available caching policies are:
none - Does not cache any user data or metadata blocks.
auto - Read caches all metadata and randomly read user data blocks, and write caches all randomly overwritten user data blocks.
Default caching-policy is auto.
[-cache-retention-priority {normal|low|high}]- Cache Retention Priority (privilege: advanced)-
This optionally specifies the cache retention priority to apply to the volume. A cache retention priority defines how long the blocks of a volume will be cached in flash pool once they become cold. If a cache retention priority is not assigned to this volume, the system uses the default policy. This parameter is available only at the advanced privilege level and higher.
The available cache retention priority are:
low - Cache the cold blocks for the lowest time.
normal - Cache the cold blocks for the default time.
high - Cache the cold blocks for the highest time.
[-is-autobalance-eligible {true|false}]- Is Eligible for Auto Balance Aggregate (privilege: advanced)-
If the Auto Balance feature is enabled, this parameter specifies whether the volume might be considered for system workload balancing. When set to
true, the Auto Balance Aggregate feature might recommend moving this volume to another aggregate. The default value istrue. [-max-constituent-size {<integer>[KB|MB|GB|TB|PB]}]- Maximum size of a FlexGroup Constituent (privilege: advanced)-
This optionally specifies the maximum size of a FlexGroup constituent. The default value is determined by checking the maximum FlexVol size setting on all nodes used by the FlexGroup. The smallest value found is selected as the default for the
-max-constituent-sizefor the FlexGroup. This parameter applies to FlexGroups only. [-efficiency-policy <efficiency policy>]- Storage Efficiency Policy (privilege: advanced)-
This optionally specifies which storage efficiency policy to apply to the volume. This parameter is applicable only for All-Flash FAS. This parameter is not supported on data protection volumes on any platform. To disable compression on the volume in All-Flash FAS, use the value
none. The default value isinline-only. [-snaplock-type {non-snaplock|compliance|enterprise}]- SnapLock Type-
This optionally specifies the SnapLock type of the volume. The default value is
non-snaplock. SnapLock is only supported with flexible volumes. [-vserver-dr-protection {protected|unprotected}]- Vserver DR Protection-
This optionally specifies whether the volume should be protected by Vserver level SnapMirror. This parameter is applicable only if the Vserver is the source of a Vserver level SnapMirror relationship. The default value for a volume of type “RW” is
protected. [-encrypt {true|false}]- Enable or Disable Encryption-
This parameter allows the user to create an encrypted volume. When it is set to
true, a new key is generated, and the volume is encrypted using the generated key. When it is set tofalse, the volume created is unencrypted. [-is-space-reporting-logical {true|false}]- Logical Space Reporting-
This optionally specifies whether to report space logically on the volume. When space is reported logically, ONTAP reports the volume space such that all the physical space saved by the storage efficiency features are also reported as used. The default setting is
false. [-is-space-enforcement-logical {true|false}]- Logical Space Enforcement-
This optionally specifies whether to perform logical space accounting on the volume. When space is enforced logically, ONTAP enforces volume settings such that all the physical space saved by the storage efficiency features will be calculated as used. The default setting is
false. [-tiering-policy <Tiering Policy>]- Volume Tiering Policy-
This optional parameter specifies the tiering policy to apply to the volume. This policy determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud tier when they become cold. FabricPool combines Flash (performance tier) with an object store (cloud tier) into a single aggregate. The default tiering policy is
snapshot-onlyfor a FlexVol andnonefor a FlexGroup. Temperature of a volume block increases if it is accessed frequently and decreases when it is not.The available tiering policies are:
snapshot-only - This policy allows tiering of only the volume Snapshot copies not associated with the active file system. The default minimum cooling period is 2 days.
auto - This policy allows tiering of both Snapshot copy data and active file system user data to the cloud tier. The default cooling period is 31 days.
none - Volume blocks will not be tiered to the cloud tier.
all - This policy allows tiering of both Snapshot copy data and active file system user data to the cloud tier as soon as possible without waiting for a cooling period. On DP volumes, this policy allows all transferred user data blocks to start in the cloud tier.
[-cloud-retrieval-policy {default|on-read|never|promote}]- Volume Cloud Retrieval Policy (privilege: advanced)-
This optional parameter specifies the cloud retrieval policy for the volume. This policy determines which tiered out blocks to retrieve from the capacity tier to the performance tier.
The available cloud retrieval policies are:
default - This policy retrieves tiered data based on the underlying tiering policy. If the tiering policy is 'auto', tiered data is retrieved only for random client driven data reads. If the tiering policy is 'none' or 'snapshot-only', tiered data is retrieved for random and sequential client driven data reads. If the tiering policy is 'all', tiered data is not retrieved.
on-read - This policy retrieves tiered data for all client driven data reads.
never - This policy never retrieves tiered data.
promote - This policy retrieves all eligible tiered data automatically during the next scheduled scan. It is only supported when the tiering policy is 'none' or 'snapshot-only'. If the tiering policy is 'snapshot-only', the only data brought back is the data in the AFS. Data that is only in a snapshot copy stays in the cloud.
[-tiering-minimum-cooling-days <integer>]- Volume Tiering Minimum Cooling Days (privilege: advanced)-
This optional parameter specifies the minimum number of days that user data blocks of the volume must be cooled before they can be considered cold and tiered out to the cloud tier. For volumes hosted on FabricPools, this parameter is used for tiering purposes and does not affect the reporting of inactive data. For volumes hosted on non-FabricPools, this parameter affects the cooling window used for the reporting of inactive data. The value specified should be greater than the frequency with which applications in the volume shift between different sets of data. Valid values are between 2 and 183. This parameter cannot be set when volume tiering policy is either "none" or "all". The default value of this parameter depends on the volume's tiering policy. See the tiering policy section of this documentation for corresponding default values. If the tiering policy on the volume gets changed, then this parameter will be reset to the default value corresponding to the new tiering policy.
[-tiering-object-tags <text>,…]- Tags to be Associated with Objects Stored on a FabricPool-
This optional parameter specifies tiering object tags to be associated with objects stored on a FabricPool.
Object tags should follow these rules:
Each object tag should be a key-value pair separated by '='.
Mulitple tags should be separated by ','. Overall tags should be in format key1=value1[,key2=value2,…].
All tags of a volume must have a unique key.
Each tag key should start with either a letter or an underscore. Keys should contain only alphanumeric characters and underscores. Maximum allowed limit is of 127 characters.
Each tag value should be of maximum 127 characters consisting of only alphanumeric characters and underscores.
Maximum 4 object tags are allowed per volume.
[-application-io-size <Application I/O Size>]- Block Size to Use by Compression (privilege: advanced) -
This optionally specifies the application IO size to apply to the volume. This parameter specifies the compression group size for enabling compression on the volume. This parameter is applicable only for All Flash FAS. This parameter is not supported on data protection volumes on any platform.
The available application I/O Sizes are:
8K
auto - ONTAP will select compression group size automatically, based on temperature of the block.
[-storage-efficiency-mode {default|efficient}]- Storage Efficiency Mode-
This optionally specifies efficiency mode of the volume.
The available efficiency modes are:
default
efficient
The
defaultmode sets 8k adaptive compression on the volume. Theefficientmode sets auto adaptive compression on the volume. This parameter is supported only on AFF platform. -
[-analytics-state <Analytics State>]- File System Analytics State-
This optionally specifies whether the volume will keep track of file system usage for the purpose of analytics. The default value is
off. [-activity-tracking-state <Activity Tracking State>]- Activity Tracking State-
This optionally specifies whether the volume will keep track of volume activity, in real time. Tracked activities include read and write traffic for files, directories, users and clients. The default value is
off. [-key-manager-attribute <text>]- Key Manager Attribute-
This optional parameter specifies an additional key manager attribute that should be an identifier-value pair separated by '=', ex. CRN=my-unique-value
The following identifiers are currently supported:
CRN
[-anti-ransomware-state {disabled|enabled|dry-run|paused|dry-run-paused|enable-paused|disable-in-progress}]- Anti-ransomware State-
Use this parameter to specify the anti-ransomware-state while creating a volume. If the value is
disabled, the volume created will have anti-ransomware feature disabled. If the value isenabled, the volume created will have anti-ransomware feature enabled and if the value isdry-run, the volume created will be in the anti-ransomware evaluation mode. [-granular-data {disabled|enabled}]- Granular data-
This specifies whether data storage on a volume is granular or not. Once this property is enabled on a volume, it cannot be disabled on that volume using this parameter. It can only be disabled on that volume by restoring a Snapshot copy. This setting may only be enabled on FlexGroups. The default value is
truefor FlexGroups andfalseotherwise. [-atime-update-period <integer>]- Access Time Update Period (Seconds) (privilege: advanced)-
This parameter specifies the time period that must be elapsed in between consecutive atime update events. Note: The value of this parameter is only used if
-atime-updateis enabled on the volume. [-snapshot-locking-enabled {true|false}]- Enable Snapshot Copy Locking-
This parameter specifies whether the Snapshot copy locking feature is enabled, based on an independent compliance-clock time. Once this property is enabled, it cannot be disabled and the volume cannot be deleted until all locked Snapshot copies are past their expiry time. The default value is false.
[-is-preserve-unlink-enabled {true|false}]- Is Preserve Unlink Enabled (privilege: advanced)-
This parameter specifies whether preserve unlink is enabled for NFSV4.1 shares on the volume. Once this feature is enabled, a file removal op on a file with existing share locks will result in the file being moved to the trash directory. Clients will continue to be able to access the file using its file handle. The last close for that file will result in deletion of the file. The default value is false.
The following example creates a new volume named user_jdoe on a Vserver named vs0 and a storage aggregate named aggr1. Upon its creation, the volume is placed in the online state. It uses the export policy named default_expolicy. The owner of the volume's root is a user named jdoe whose primary group is named dev. The volume's junction path is /user/jdoe. The volume is 250 GB in size, space for the entire volume is reserved on the aggregate, and the create operation runs in the background.
cluster1::> volume create -vserver vs0 -volume user_jdoe -aggregate aggr1
-state online -policy default_expolicy -user jdoe -group dev
-junction-path /user/jdoe -size 250g -space-guarantee volume
-percent-snapshot-space 20 -foreground false
The following example creates a new volume named vol_cached on a Vserver named vs0 and a Flash Pool storage aggregate named aggr1. The newly created volume is placed online and uses auto as the caching policy.
cluster1::> volume create -vserver vs0 -volume vol_cached -aggregate aggr1
-state online -caching-policy auto
The following example creates a new FlexGroup named media_vol on a Vserver named vs0 with four constituents on aggregates aggr1 and aggr2. Upon its creation, the volume is placed in the online state. The volume's junction path is /media. The volume is 200 TB in size, no space for the volume is reserved on the aggregates, and the create operation runs in the background.
cluster1::> volume create -vserver vs0 -volume media_vol
-aggr-list aggr1,aggr1,aggr2,aggr2 -junction-path /media -size 200TB
-space-guarantee none -foreground false
The following example creates a new FlexGroup volume named fg on a Vserver named vs0 on aggregates selected by Data ONTAP.
cluster1::> volume create -vserver vs0 -volume fg -auto-provision-as flexgroup
