cluster agent connection modify
Modify agent connection
Modify agent connection properties.
-name <text>- Name (privilege: advanced)-
Specify connection name.
[-destination <text>]- Destination URL (privilege: advanced)-
Specify destination URL. For secure websocket, this should be amqpwss://<host[:port]>
[-use-proxy {true|false}]- Use Proxy (privilege: advanced)-
Establish this connection through the HTTP Proxy server associated with this connection's IPspace.
[-subscribe-address <text>]- Subscribe Address (privilege: advanced)-
AMQP address to which ONTAP will subscribe. Defaults to "ontap.agent.manager".
[-publish-address <text>]- Publish Address (privilege: advanced)-
AMQP address to which ONTAP will publish. Defaults to "ontap.agent.cluster".
[-certificate-uuid <UUID>]- Auth Certificate UUID (privilege: advanced)-
Specify uuid of an existing certificate to use for authentication to the destination.
[-certificate-name <text>]- Auth Certificate Name (privilege: advanced)-
Specify name of certificate to be used for authentication to the destination. If paired with certificate-private-key, it names the new certificate.
[-csr-token <text>]- Auth CSR Token (privilege: advanced)-
Token for authenticating with CSR URL. Not audited.
[-idle-timeout <integer>]- Idle Timeout (privilege: advanced)-
AMQP idle timeout. Defaults to 0. If set, the local peer will disconnect if it does not receive AMQP frames within the timeout
[-address-family {unknown|ipv4|ipv6}]- Address Family (privilege: advanced)-
Specify address family.
[-auto-delete-error-minutes <integer>]- Auto-delete when disconnected for specified minutes (privilege: advanced)-
Specify time to live in minutes for cloud agent connection in error state. Connection will be deleted if it stays in error state beyond this time.
cluster-1::> cluster agent connection modify -name cloud_agent -destination amqpwss://new-manager.example.com
