ONTAP commands
vserver fcp ping-initiator show
Ping FCP initiator
This command performs a connectivity check (ping) between FCP initiators and FCP LIFs.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to select the Vservers that contain FCP initiators and FCP LIFs.
-wwpn <text> - Remote WWPN
Use this parameter to select the remote WWPN (most likely, FCP initiator).
[-lif <text>] - LIF Name
Use this parameter to limit the test to a subset of the FCP LIFs available for the igroup.
[-check-fabric <true>] - Query Fabric Records (privilege: advanced)
Use this parameter to query the unzoned name server for the FCP initiator WWPN.
[-node <nodename>] - Node
Use this parameter to select the nodes that contain the specified FCP LIFs.
[-status {unknown|reachable|not-reachable|not-zoned|cannot-ping-same-wwpn|fcp-service-busy|lif-is-down|zone-info-not-available}] - Ping Status
Use this parameter to select the result of FCP ping command.
[-ext-status {logged-in|not-logged_in|not-in-fabric|not-in-same-zone|fabric-info-not-available}] - Extended Status
Use this parameter to select the extended result of FCP ping command.
cluster1::> vserver fcp ping-initiator show
                         Node       Logical   Ping      Extended
Vserver   WWPN           Name       Interface Status    Status
vserver_1
          c0:03:ff:e4:70:06:00:e4
                         node_1
                                    lif_1     reachable wwpn-logged-in
          c0:03:ff:e4:70:06:00:e6
                         node_2
                                    lif_2     not-zoned -
2 entries were displayed.
