vserver fcp ping-initiator show
Ping FCP initiator
This command performs a connectivity check (ping) between FCP initiators and FCP LIFs.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Use this parameter to select the Vservers that contain FCP initiators and FCP LIFs.
-wwpn <text>
- Remote WWPN-
Use this parameter to select the remote WWPN (most likely, FCP initiator).
[-lif <text>]
- LIF Name-
Use this parameter to limit the test to a subset of the FCP LIFs available for the igroup.
[-check-fabric <true>]
- Query Fabric Records (privilege: advanced)-
Use this parameter to query the unzoned name server for the FCP initiator WWPN.
[-node <nodename>]
- Node-
Use this parameter to select the nodes that contain the specified FCP LIFs.
[-status {unknown|reachable|not-reachable|not-zoned|cannot-ping-same-wwpn|fcp-service-busy|lif-is-down|zone-info-not-available}]
- Ping Status-
Use this parameter to select the result of FCP ping command.
[-ext-status {logged-in|not-logged_in|not-in-fabric|not-in-same-zone|fabric-info-not-available}]
- Extended Status-
Use this parameter to select the extended result of FCP ping command.
cluster1::> vserver fcp ping-initiator show Node Logical Ping Extended Vserver WWPN Name Interface Status Status --------- -------------- ---------- --------- --------- ----------- vserver_1 c0:03:ff:e4:70:06:00:e4 node_1 lif_1 reachable wwpn-logged-in c0:03:ff:e4:70:06:00:e6 node_2 lif_2 not-zoned - 2 entries were displayed.
