system health config show
Display system health configuration
The system health config show command displays the configuration and status of each health monitor in the cluster. The command shows a health status for each health monitor. The health status is an aggregation of the subsystem health for each subsystem that the health monitor monitors. For example, if a health monitor monitors two subsystems and the health status of one subsystem is "ok" and the other is "degraded", the health status for the health monitor is "degraded".
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Use this parameter to list the health monitors present on the specified node.
[-monitor <hm_type>] - Monitor
Use this parameter to display the health monitors with the specified monitor name.
[-subsystem <hm_subsystem>,…​] - Subsystem
Selects the health monitors with the specified subsystems.
[-health {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Health
Selects the health monitors with the specified health status.
[-mon-version <text>] - Monitor Version
Selects the health monitors with the specified monitor version.
[-pol-version <text>] - Policy File Version
Selects the health monitors with the specified health monitor policy version.
[-context {Node |Cluster}] - Context
Selects the health monitors with the specified running context.
[-aggregator <hm_type>] - Aggregator
Selects the health monitors with the specified aggregator.
[-resources <text>,…​] - Resource
Selects the health monitors with the specified resource name.
[-init-state {Invalid|Initailizing|Initialized|Starting_Discovery|Starting_Re-Discovery|Discovery_Done_Partially|Discovery_Done}] - Subsystem Initialization Status
Selects the health monitors with the specified subsystem initialization state.
[-sub-pol-versions <text>] - Subordinate Policy Versions
Selects the health monitors with the specified subordinate policy version.
The example below displays information about health monitor configuration:
cluster1::> system health config show
Node          Monitor                Subsystem         Health
node1         node-connect           SAS-connect       degraded
node1         system-connect         SAS-connect       degraded
node1         system                 SAS-connect       degraded
The example below displays detailed information about health monitor configuration:
cluster1::> system health config show -instance
Node: node1
                               Monitor: node-connect
                             Subsystem: SAS-connect
                                Health: degraded
                       Monitor Version: 1.0
                   Policy File Version: 1.0
                               Context: node_context
                            Aggregator: system-connect
                              Resource: SasAdapter, SasDisk, SasShelf
       Subsystem Initialization Status: initialized
           Subordinate Policy Versions: 1.0 SAS, 1.0 SAS multiple adapters
