security login publickey delete
Delete a public key
The security login publickey delete command deletes a public key for a specific user. To delete a public key, you must specify a user name and index number.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver of the user for whom you are adding the public key.
-username <text>- Username-
This parameter specifies the name of the user for whom you are deleting a public key. If you do not specify a user, the user named admin is specified by default.
-index <integer>- Index-
This parameter specifies an index number for the public key.
The following command deletes the public key for the user named tsmith with the index number 5.
cluster1::> security login publickey delete -username tsmith -index 5
