security login publickey load-from-uri
Load one or more public keys from a URI
The security login publickey load-from-uri command loads one or more public keys from a Universal Resource Identifier (URI). To load public keys from a URI, you must specify a user name, the URI from which to load them, and optionally, whether you want to overwrite the existing public keys.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver for the user associated with the public keys.
-username <text>- Username-
This parameter specifies the username for the public keys. If you do not specify a username, the username
"admin"is used by default. -uri {(ftp|http|https)://(hostname|IPv4 Address|'['IPv6 Address']')…}- URI to load from-
This parameter specifies the URI from which the public keys will be loaded.
-overwrite {true|false}- Overwrite Entries-
This parameter optionally specifies whether you want to overwrite existing public keys. The default value for this parameter is
false. If the value istrueand you confirm to overwrite, then the existing public keys are overwritten with the new public keys. If you use the valuefalseor do not confirm the overwrite, then newly loaded public keys are appended to the list of existing public keys using the next available index.
The following command shows how to load public keys for the user named tsmith from the URI ftp://ftp.example.com/identity.pub. This user's existing public keys are not overwritten.
cluster1::> security login publickey load-from-uri -username tsmith -uri ftp://ftp.example.com/identity.pub -overwrite false
The following command shows how to load public keys for the user named tsmith from the URI ftp:ftp://ftp.example.com/identity.pub. This user's existing public keys are overwritten if user entered the option 'y' or 'Y'. The user's existing public keys are not overwritten if user entered the option 'n' or 'N' and the newly loaded public keys are appended to the list of existing public keys using the next available index. The user and password credentials that you provide when you use this command are the credentials to access the server specified by the URI.
tsmith -uri ftp://ftp.example.com/identity.pub -overwrite true -vserver vs0
Enter User:
Enter Password:
Warning: You are about to overwrite the existing publickeys for the user
"tsmith" in Vserver "vs0". Do you want to proceed? {y|n}:
