ONTAP commands
lun move show
Display a list LUNs currently being moved
The lun move show command shows information about LUNs currently being moved in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Selects LUN move operations that match this parameter value.
[-destination-path <text>] - Destination Path
[-source-path <path>] - Source Path
[-is-promoted-late {true|false}] - Is Destination Promoted Late
[-max-throughput {<integer>[KB|MB|GB|TB|PB]}] - Maximum Transfer Rate (per sec)
[-job-status {Preparing|Allocation-Map|Data|Destroying|Paused-Manual|Paused-Error|Complete|Destroyed|Terminated-Manual}] - LUN Move Status
Selects LUN move operations that match this parameter value. The possible values are:
  • Preparing - the LUN move job is in Preparing status.
  • Allocation-Map - the LUN move job is in Allocating status.
  • Data - the LUN move job is in Moving Data status.
  • Destroying - the LUN move job is in Destroying status.
  • Paused-Manual - the LUN move job is in Manually Paused status.
  • Paused-Error - the LUN move job is in Paused By Error status.
  • Complete - the LUN move job is in Complete status.
  • Destroyed - the LUN move job is in Destroyed status.
  • Terminated-Manual - the LUN move job is in Manually Terminated status.
[-progress-percent <percent>] - LUN Move Progress (%)
[-elapsed-time <time_interval>] - Elapsed Time
[-cutover-time <time_interval>] - Cutover Time
[-is-snapshot-fenced {true|false}] - Is Snapshot Fenced
[-is-destination-ready {true|false}] - Is Destination Ready
[-last-failure-reason <text>] - Last Failure Reason
cluster1::> lun move show
Vserver   Destination Path                Status          Progress
vs1       /vol/vol2/lun1                  Data            35%
vs1       /vol/vol2/lun2                  Complete        100%
2 entries were displayed.
The example above displays information about all the LUN move operations in the cluster.
cluster1::> lun move show -vserver vs1 -destination-path /vol/vol2/lun1 -instance
Destination Vserver Name: vs1
               Destination Path: /vol/vol2/lun1
                    Source Path: /vol/vol1/lun1
  Is Destination Promoted Early: false
Maximum Transfer Rate (per sec): 0B
                LUN Move Status: Data
          LUN Move Progress (%): 35%
                   Elapsed Time: 145s
            Cutover Time (secs): 0s
             Is Snapshot Fenced: true
           Is Destination Ready: true
            Last Failure Reason: -
The example above displays all information about the LUN being moved to /vol/vol2/lun1 in Vserver vs1 .
Looking for answers?
Try Doc, our Gen AI Assistant.
