lun move show
Display a list LUNs currently being moved
The lun move show command shows information about LUNs currently being moved in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Selects LUN move operations that match this parameter value.
[-destination-path <text>]- Destination Path-
[-source-path <path>]- Source Path-
[-is-promoted-late {true|false}]- Is Destination Promoted Late-
[-max-throughput {<integer>[KB|MB|GB|TB|PB]}]- Maximum Transfer Rate (per sec)-
[-job-status {Preparing|Allocation-Map|Data|Destroying|Paused-Manual|Paused-Error|Complete|Destroyed|Terminated-Manual}]- LUN Move Status-
Selects LUN move operations that match this parameter value. The possible values are:
Preparing- the LUN move job is in Preparing status. -
Allocation-Map- the LUN move job is in Allocating status. -
Data- the LUN move job is in Moving Data status. -
Destroying- the LUN move job is in Destroying status. -
Paused-Manual- the LUN move job is in Manually Paused status. -
Paused-Error- the LUN move job is in Paused By Error status. -
Complete- the LUN move job is in Complete status. -
Destroyed- the LUN move job is in Destroyed status. -
Terminated-Manual- the LUN move job is in Manually Terminated status.
[-progress-percent <percent>]- LUN Move Progress (%)-
[-elapsed-time <time_interval>]- Elapsed Time-
[-cutover-time <time_interval>]- Cutover Time-
[-is-snapshot-fenced {true|false}]- Is Snapshot Fenced-
[-is-destination-ready {true|false}]- Is Destination Ready-
[-last-failure-reason <text>]- Last Failure Reason-
cluster1::> lun move show Vserver Destination Path Status Progress --------- ------------------------------- --------------- -------- vs1 /vol/vol2/lun1 Data 35% vs1 /vol/vol2/lun2 Complete 100% 2 entries were displayed.
The example above displays information about all the LUN move operations in the cluster.
cluster1::> lun move show -vserver vs1 -destination-path /vol/vol2/lun1 -instance
Destination Vserver Name: vs1
Destination Path: /vol/vol2/lun1
Source Path: /vol/vol1/lun1
Is Destination Promoted Early: false
Maximum Transfer Rate (per sec): 0B
LUN Move Status: Data
LUN Move Progress (%): 35%
Elapsed Time: 145s
Cutover Time (secs): 0s
Is Snapshot Fenced: true
Is Destination Ready: true
Last Failure Reason: -
The example above displays all information about the LUN being moved to /vol/vol2/lun1 in Vserver vs1 .
