security session limit request delete
Delete per-request session limit
This command allows deletion of a per-request management session limit.
-interface {cli|ontapi|rest} - Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-request <text> - Request Name (privilege: advanced)
The specified request to which this limit applies. The limit with the request name -default- is the limit used for any request without a specific configured limit.
The following example illustrates deleting custom limits for that were configured for the volume commands and APIs.
cluster1::*> security session limit request delete -interface * -request volume*
4 entries were deleted.
