security session limit request delete
Delete per-request session limit
This command allows deletion of a per-request management session limit.
- -interface {cli|ontapi|rest}- Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
- -request <text>- Request Name (privilege: advanced)
The specified request to which this limit applies. The limit with the request name -default-is the limit used for any request without a specific configured limit.
The following example illustrates deleting custom limits for that were configured for the volume commands and APIs.
cluster1::*> security session limit request delete -interface * -request volume* 4 entries were deleted.
 PDFs
PDFs
