security cryptomod-fips show
Display the status of cryptomod-fips
This command displays information about the status of the cryptomod FIPS module. By default, this command displays the following information:
Node name
FIPS version
Module version
FIPS state
Boolean indicating if module is a user-space module
Boolean indicating if module is operating in FIPS mode
Boolean indicating if module is currently under validation
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the nodes that match this parameter value.
[-fips-state-text <text>]- FIPS State-
Shows the FIPS state of the module.
POWER ON STATE
SELF-TEST STATE
ERROR STATE
OPERATE STATE
POWER OFF STATE
[-fips-version <text>]- FIPS Version-
Shows the FIPS version.
[-module-version <text>]- Module Version-
Shows the cryptomod FIPS module version.
[-is-user-space-module {true|false}]- Is User Space Module?-
True if the module is a user-space module.
[-is-fips-enabled {true|false}]- Is FIPS Mode Enabled?-
True if the module is operating in FIPS mode.
[-is-iut-enabled {true|false}]- Is an IUT Module Enabled?-
True if the module is currently under validation.
cluster1::> security cryptomod-fips show
Node FIPS FIPS Module
State Version Version
node-1 OPERATE STATE 140-2 2.2
node-2 OPERATE STATE 140-2 2.2
