security cryptomod-fips show
Display the status of cryptomod-fips
This command displays information about the status of the cryptomod FIPS module. By default, this command displays the following information:
Node name
FIPS version
Module version
FIPS state
Boolean indicating if module is a user-space module
Boolean indicating if module is operating in FIPS mode
Boolean indicating if module is currently under validation
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the nodes that match this parameter value.
[-fips-state-text <text>]
- FIPS State-
Shows the FIPS state of the module.
POWER ON STATE
SELF-TEST STATE
ERROR STATE
OPERATE STATE
POWER OFF STATE
[-fips-version <text>]
- FIPS Version-
Shows the FIPS version.
[-module-version <text>]
- Module Version-
Shows the cryptomod FIPS module version.
[-is-user-space-module {true|false}]
- Is User Space Module?-
True if the module is a user-space module.
[-is-fips-enabled {true|false}]
- Is FIPS Mode Enabled?-
True if the module is operating in FIPS mode.
[-is-iut-enabled {true|false}]
- Is an IUT Module Enabled?-
True if the module is currently under validation.
cluster1::> security cryptomod-fips show Node FIPS FIPS Module State Version Version ------ --------------- ------- --------- node-1 OPERATE STATE 140-2 2.2 node-2 OPERATE STATE 140-2 2.2
