security cryptomod-fips show
Display the status of cryptomod-fips
This command displays information about the status of the cryptomod FIPS module. By default, this command displays the following information:
Node name
FIPS version
Module version
FIPS state
Boolean indicating if module is a user-space module
Boolean indicating if module is operating in FIPS mode
Boolean indicating if module is currently under validation
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Selects the nodes that match this parameter value.
- [-fips-state-text <text>]- FIPS State
Shows the FIPS state of the module. -
POWER ON STATE
SELF-TEST STATE
ERROR STATE
OPERATE STATE
POWER OFF STATE
- [-fips-version <text>]- FIPS Version
Shows the FIPS version.
- [-module-version <text>]- Module Version
Shows the cryptomod FIPS module version.
- [-is-user-space-module {true|false}]- Is User Space Module?
True if the module is a user-space module.
- [-is-fips-enabled {true|false}]- Is FIPS Mode Enabled?
True if the module is operating in FIPS mode.
- [-is-iut-enabled {true|false}]- Is an IUT Module Enabled?
True if the module is currently under validation.
cluster1::> security cryptomod-fips show
Node   FIPS            FIPS    Module
       State           Version Version
node-1 OPERATE STATE   140-2   2.2
node-2 OPERATE STATE   140-2   2.2
 PDFs
PDFs
