ONTAP commands
security cryptomod-fips show
Display the status of cryptomod-fips
This command displays information about the status of the cryptomod FIPS module. By default, this command displays the following information:
  • Node name
  • FIPS version
  • Module version
  • FIPS state
  • Boolean indicating if module is a user-space module
  • Boolean indicating if module is operating in FIPS mode
  • Boolean indicating if module is currently under validation
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the nodes that match this parameter value.
[-fips-state-text <text>] - FIPS State
Shows the FIPS state of the module.
  • POWER ON STATE
  • SELF-TEST STATE
  • ERROR STATE
  • OPERATE STATE
  • POWER OFF STATE
[-fips-version <text>] - FIPS Version
Shows the FIPS version.
[-module-version <text>] - Module Version
Shows the cryptomod FIPS module version.
[-is-user-space-module {true|false}] - Is User Space Module?
True if the module is a user-space module.
[-is-fips-enabled {true|false}] - Is FIPS Mode Enabled?
True if the module is operating in FIPS mode.
[-is-iut-enabled {true|false}] - Is an IUT Module Enabled?
True if the module is currently under validation.
cluster1::> security cryptomod-fips show
Node   FIPS            FIPS    Module
       State           Version Version
node-1 OPERATE STATE   140-2   2.2
node-2 OPERATE STATE   140-2   2.2
