volume efficiency inactive-data-compression show
Display volume inactive data compression progress
The volume efficiency inactive-data-compression show command is used to show details of inactive data compression on a volume.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name (privilege: advanced)
This specifies the vserver of the volume.
- [-volume <volume name>]- Volume Name (privilege: advanced)
This specifies the volume on which inactive data compression should be started.
- [-progress <text>]- Progress (privilege: advanced)
Progress of the scan.
- [-status <text>]- Status (privilege: advanced)
Operation on the scan succeeded or failed.
- [-failure-reason <text>]- Failure Reason (privilege: advanced)
If scan failed, the reason of the failure.
- [-total-blocks <integer>]- Total Blocks to be Processed (privilege: advanced)
Total number of blocks which must be processed by inactive data compression scanner.
- [-total-processed <integer>]- Total Blocks Processed (privilege: advanced)
Total number of blocks which are already processed by inactive data compression scanner.
- [-percentage <percent>]- Progress (privilege: advanced)
Scan progress in percentage.
- [-cold-blocks-found <integer>]- Number of Cold Blocks encountered (privilege: advanced)
Number of cold blocks encountered by inactive data compression scanner.
- [-compression-done <integer>]- Number of Compression Done Blocks (privilege: advanced)
Number of blocks on which compression was done.
- [-vol-overwrites <integer>]- Number of Vol-Overwrites (privilege: advanced)
count of logical blocks overwritten in compressed data extents.
- [-is-enabled {true|false}]- State of Inactive Data Compression on the Volume (privilege: advanced)
Is scan enabled on the volume.
- [-last-op-start-time <integer>]- Time since Last Inactive Data Compression Scan started (privilege: advanced)
Time since the last inactive data compression scan op started.
- [-last-op-end-time <integer>]- Time since Last Inactive Data Compression Scan ended (privilege: advanced)
Time since the last inactive data compression scan op ended.
- [-last-succ-op-start-time <integer>]- Time since Last Successful Inactive Data Compression Scan started (privilege: advanced)
Time since the last successful inactive data compression scan op started.
- [-last-succ-op-end-time <integer>]- Time since Last Successful Inactive Data Compression Scan ended (privilege: advanced)
Time since the last successful inactive data compression scan op ended.
- [-average-run-time <integer>]- Average run time for Inactive Data Compression Scan (privilege: advanced)
Average runtime of inactive data compression.
- [-threshold-days <integer>]- Inactive data compression scan threshold days value (privilege: advanced)
Threshold days value for inactive data compression scan.
- [-threshold-days-min <integer>]- Inactive data compression scan threshold minimum allowed value. (privilege: advanced)
Minimum allowed value in threshold days for inactive data compression scan.
- [-threshold-days-max <integer>]- Inactive data compression scan threshold maximum allowed value. (privilege: advanced)
Maximum allowed value in threshold days for inactive data compression scan.
- [-read-history-window-size <integer>]- Time window(in days) for which client reads data is collected for tuning. (privilege: advanced)
Client read history window.
- [-tuning-enabled {true|false}]- State of auto-tuning of Inactive data compression scan on volume. (privilege: advanced)
Auto-tuning state of inactive data compression scan.
- [-compression-algorithm {lzopro|zstd}]- Inactive data compression algorithm (privilege: advanced)
Inactive data compression algorithm.
- [-scan-mode {default|compute_compression_savings}]- Mode of Inactive data compression scan (privilege: advanced)
Mode of the Inactive data compression scanner.
The following example displays details about the inactive data compression on volume "vol1":
cluster:::> volume efficiency inactive-data-compression show -vserver vs1 -volume vol1
Volume: vol1
                     Vserver: vs1
                  Is Enabled: true
                                                        Progress: IDLE
                Status: SUCCESS
             Compression Algorithm: lzopro
              Failure Reason:  -
                                                   Total Blocks:  -
                                          Total Blocks Processed:  -
                  Percentage:  -
                               Number of Cold Blocks Encountered:  -
             Number of Compression Done Blocks:  -
                                     Number of Vol-Overwrites:  -
     Time since Last Inactive Data Compression Scan Started(sec):  -
       Time since Last Inactive Data Compression Scan Ended(sec):  -
Time since Last Successful Inactive Data Compression Scan Started(sec):  -
  Time since Last Successful Inactive Data Compression Scan Ended(sec):  -
         Average runtime of Inactive Data Compression(sec):  -
              Tuning Enabled: true
                   Threshold: 14
             Threshold Upper Limit: 21
             Threshold Lower Limit: 14
              Client Read history window: 14
 PDFs
PDFs
