vserver name-mapping create
Create a name mapping
The vserver name-mapping create command creates a name mapping. Name mappings are applied in the order in which they occur in the priority list; for example, a name mapping that occurs at position 2 in the priority list is applied before a name mapping that occurs at position 3. Each mapping direction (Kerberos-to-UNIX, Windows-to-UNIX, UNIX-to-Windows, S3-to-UNIX and S3-to-Windows) has its own priority list. Data ONTAP prevents you from creating two name mappings with the same pattern.
Patterns can be expressed as POSIX regular expressions. For information about regular expressions, see the UNIX reference page for regex(7) .
Each Vserver can have up to 12500 name mappings in each direction.
If you are using the CLI, you must delimit all regular expressions with double quotation marks ("). For instance, to enter the regular expression (.)_`` in the CLI, type ``_"(.)" at the command prompt. To add a "?" to the expression, press ESC followed by the "?".
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver on which you want to create the name mapping.
-direction {krb-unix|win-unix|unix-win|s3-unix|s3-win}- Direction-
This parameter specifies the direction of the name mapping. Possible values are
krb-unixfor a Kerberos-to-UNIX name mapping,win-unixfor a Windows-to-UNIX name mapping,unix-winfor a UNIX-to-Windows name mapping,s3-unixfor a S3-to-UNIX name mapping ands3-winfor a S3-to-Windows name mapping. -position <integer>- Position-
This parameter specifies the name mapping's position in the priority list. Specify the position as a positive integer.
If you want to create a new name mapping at a position that is already occupied in the priority list, use the vserver name-mapping insert command instead of the vserver name-mapping createcommand. -pattern <text>- Pattern-
This parameter specifies the pattern you want to match. Refer to the command description section for details. The pattern can be up to 256 characters in length.
-replacement <text>- Replacement-
This parameter specifies the replacement pattern. The replacement pattern can be up to 256 characters in length.
[-address <IP Address/Mask>]- IP Address with Subnet Mask -
This optional parameter specifies the IP address that can be used to match the client's workstation IP address with the pattern.
[-hostname <text>]- Hostname } -
This optional parameter specifies the hostname that can be used to match the corresponding client's workstation IP address with the list of IP addresses with the pattern.
The following example creates a name mapping on a Vserver named vs1. The mapping is from UNIX to Windows at position 5 in the priority list. The mapping maps the pattern cifs to the replacement EXAMPLE\Domain Users.
cluster1::> vserver name-mapping create -vserver vs1 -direction unix-win -position 5 -pattern cifs -replacement "EXAMPLE\\Domain Users -address 10.238.33.245/24" cluster1::> vserver name-mapping create -vserver vs1 -direction unix-win -position 5 -pattern cifs -replacement "EXAMPLE\\Domain Users -hostname google.com"
