statistics workload show
QoS workload throughput and latency metrics
This command continuously displays performance data for workloads at a regular interval. The command output displays data in the following columns:
Workload - workload name.
Total Ops - total number of operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
Other Ops - other operations per second.
Read (Bps) - read throughput in bytes per second.
Write (Bps) - write throughput in bytes per second.
Latency(us) - average latency for an operation in microseconds.
[-workload <text>]- Workload (privilege: advanced)-
Selects the workload for which you want to display performance data.
 [-sort-key <text>]- Column to Sort By (privilege: advanced)-
If this parameter is specified, the command displays statistics sorted by the specified column.
 -interval <integer>- Interval (privilege: advanced)-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
 -iterations <integer>- Iterations (privilege: advanced)-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
 -max <integer>- Maximum Number of Instances (privilege: advanced)-
Specifies the maximum number of workloads to display. The default setting is 25.
The following example displays workload statistics:
cluster1::> statistics workload show
cluster1 : 12/31/2013 16:00:04
                 *Total Read Write Other   Read Write Latency
        Workload    Ops  Ops   Ops   Ops  (Bps) (Bps)    (us)
 _USERSPACE_APPS     30    1     3     0  30765  8553       0
      _WAFL_SCAN     20    0     0     0     0      0       0
        _WAFL_CP      0    0     0     0     0      0       -
