statistics workload show
QoS workload throughput and latency metrics
This command continuously displays performance data for workloads at a regular interval. The command output displays data in the following columns:
Workload - workload name.
Total Ops - total number of operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
Other Ops - other operations per second.
Read (Bps) - read throughput in bytes per second.
Write (Bps) - write throughput in bytes per second.
Latency(us) - average latency for an operation in microseconds.
[-workload <text>]
- Workload (privilege: advanced)-
Selects the workload for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By (privilege: advanced)-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval (privilege: advanced)-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations (privilege: advanced)-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances (privilege: advanced)-
Specifies the maximum number of workloads to display. The default setting is 25.
The following example displays workload statistics:
cluster1::> statistics workload show cluster1 : 12/31/2013 16:00:04 *Total Read Write Other Read Write Latency Workload Ops Ops Ops Ops (Bps) (Bps) (us) --------------- ------ ---- ----- ----- ------ ----- ------- _USERSPACE_APPS 30 1 3 0 30765 8553 0 _WAFL_SCAN 20 0 0 0 0 0 0 _WAFL_CP 0 0 0 0 0 0 - [...]
