vserver vscan show
Display Vscan status
The `vserver vscan show ` command displays Vscan status information of the Vservers. If you do not specify any parameters, the command displays the following information about all Vservers:
  • Vserver name
  • Vscan status
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the specified Vserver.
[-vscan-status {on|off}] - Vscan Status
If you specify this parameter, the command displays information only about the Vservers that have the specified status.
The following example displays the Vscan status information.
cluster1::> vserver vscan show
Vserver          Vscan Status
vs1              on
vs2              off
2 entries were displayed.
