vserver vscan show
PDF of this doc site
Creating your file...
Display Vscan status
The `vserver vscan show ` command displays Vscan status information of the Vservers. If you do not specify any parameters, the command displays the following information about all Vservers:
Vserver name
Vscan status
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the specified Vserver.
[-vscan-status {on|off}]
- Vscan Status-
If you specify this parameter, the command displays information only about the Vservers that have the specified status.
The following example displays the Vscan status information.
cluster1::> vserver vscan show Vserver Vscan Status -------------- ------------ vs1 on vs2 off 2 entries were displayed.
